ZC Sohc Swap Questions
Discussion in 'Civic and CRX - EF' started by douglaslovin, Jul 27, 2008.
  1. douglaslovin
    douglaslovin New Member
    Conroe, Tx
    I have a 1990 hatchback and it currently has a D15B1 w/ 5sp standard tranny. It's old and junky and the cost to rebuild it exceeds the cost to just buy a swap.
    The engine I am looking at getting is the SOHC ZC from hmotorsonline.com Here is the link to the engine I want. http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30020
    It comes with the following:
    - Motor
    - Intake Manifold
    - Exhaust Manifold
    - Injectors
    - Fuel Rail
    - Throttle body
    - Alternator
    - Distributor
    - 5 Speed ZC Transmission(Add $200) - I am buying as well.
    - Motors (what ever this is)
    What else will I need to buy and do to complete this swap?
    DPFI to MPFI?
    New Axles?
    Different Mounts?
    Any help is appreciated. Thanks guys!
  2. hosmer
    B R I D G E W A T E R
    DPFI to MPFI and an ECU
    motor mounts and axles are the same
    -that motor is the same as a D16A6 out of an Si...only difference is the cam which you can pickup for like $100 or get a regrind for yours...
  3. douglaslovin
    Conroe, Tx
    Thanks for the advice. This is going to be an easy swap then.
