Zc Sohc Vs Zc Dohc
Discussion in 'HYBRID -> EG-EK / DC' started by delsolty, Apr 2, 2003.
  1. delsolty
    delsolty Senior Member
    Ok I have the stock motor that come out my CRX 91 SI. Ok I want to know, to make sure. I can put a ZC head on the si block right???? Ok and I don't know if I want to go with the SOHC or the DOHC. Right now I have a DOHC in my CRX. But I think I want to try the SOHC out. Cuz I got a pal that has one in a 91 HB and he likes it. So tell me what you think??? Thx
  2. b18vtecrx
    b18vtecrx Senior Member
    go with a DOHC ZC motor and then put a junkyard turbo setup on it thats pretty easy to do and very cheap im getting a ZC motor today or tomorrow for only about 100 bucks! well lemme know how things work out for ya.... later
  3. phunky.buddha
    Dallas / Fort Worth, TX
    You can't swap between SOHC and DOHC heads. If you already have a DOHC D block in there, you're not running the stock engine. If you want to try out a SOHC engine, you'll have to pull the whole engine, not just the head. SOHC ZC engines are pretty hard to come by, so you might just want to switch to a SOHC VTEC if you want to go SOHC D series. In any case, the DOHC ZC is the most powerful D series block (stock), so going to a SOHC powerplant will make your power levels drop a bit.
  4. HkDx
    HkDx New Member
    dohc-sohc?
    so you can switch the heads on a zc block to make it dohc or sohc?
  5. Dark93DX
    Dark93DX New Member
    B.C.
    This thread is 6yrs old.
  6. buttered corn
    buttered corn New Member
    'nuff said.
