zc swap help...into 91 crx hf
Discussion in 'HYBRID -> ED-EF / DA' started by pyro_freak8, Mar 24, 2004.
  1. pyro_freak8
    pyro_freak8 Junior Member
    i have a 91 crx hf that i just dropped a DOHC ZC into, the engine came with an si engine harness and my car is an hf, everything plugged in fine, but when i tried to start it i don't get any spark.... if i let th car sit for a few minutes and come back and turn the key to the second position it will give one spark, then when you try to start it nothing.... i'm also getting a CEL code 15(igniton output system)...is this because i need to use the hf engine harness? anyone?
  2. pyro_freak8
    ttt.....anyone?
  3. HondaMoCo
    HondaMoCo Senior Member
    lancaster/palmdale So Cal
    yea, take off the si harness and plug in your HF harness, all you have to do is take the two blue wires from the distributor plug, blue/yellow, blue/green and run it over to the Cam angle Sensor on the exhaust cam. when you do a swap, you should generally try to stick with your stock engine harness.
  4. pyro_freak8
    got it running....runs great... thanks..
  5. crx
    crx Senior Member
    cali near sac
    you could use the si all you have to do is run the ignitor wire from the pass shocktower(si) to the drivers side(hf)
