allmotord16rex
OK, i have the motor in and it runs. It is currently throwing a code 9, I have worked all the codes out but this one. Whenever I drive it, it is very, very slow and I cant figure out why. All the vacuum lines are correct and everything is hooked up. I cant figure out if it has a bad distributor, or if the cam angle sensor is bad. It is under warranty and a new distributor is on the way. Also, i need to check the ignition timing. Is it common practice to check the ignition when finishing the swap. All of the people I know that did swaps just swapped and drove away. Basically, what I want to know is can a bad distributor or cam angle sensor cause a car to be terribly slow? I mean it is much slower than my SI engine was. Please help guys. Thanks.
