allmotord16rex
OK, my ZC is on its way as we speak. I have a few things to clear up before it arrives and I begin the swap. I have a 90 CRX Si by the way. OK, when getting ready to put the engine in, do you have to put the drivers side mounting bracket onto the timing belt side of the zc for the mount to work? Does this only have to be done for the d16a1 usdm integra engine? Or do the stock mounts just go right onto the motor. I know when doing the d16z6 swap that you have to put the a6 drivers side bracket onto it and I need to know if you need to for ZC swap also. Thanks.
