ZC swap to std
Discussion in 'HYBRID -> ED-EF / DA' started by BoogieDown, Apr 5, 2004.
  1. BoogieDown
    BoogieDown Senior Member
    Tampa FLA
    do i need Si hubs and axles or can i use DX hubs and axles i have a 4speed?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    DX will work.
  3. brian11to1
    brian11to1 Senior Member
    DX or Si. They are the same. Both will work.
  4. BoogieDown
    Tampa FLA
    sorry for a the noob questions this is my first honda swap i have done. all that stuff i know has 4 more cyls and 400hp. i use to rag on imports till i started reading more about them and seen what can be done to them. nuff w/ that do i use the axles from the car i get the axles from? or ZC axles and when i call Nappa does year or model matter? again sorry for all the noob questions
  5. brian11to1
    I believe you use axles from a 88-91 Civic or CRX. Im not sure. Look into this.
  6. brian11to1
  7. 81crx88zc
    81crx88zc Junior Member
    u using the dx trans or a zc?
  8. BoogieDown
    Tampa FLA
    still in the process of finding a good importer. know of any? not too worried about price just want quality
  9. BoogieDown
    Tampa FLA
    probly the easier of the 2 trannys to get my hands on
  10. 81crx88zc
    zc trany is totally worth getting your hands on. It is lower gearing and has a limited slip. only down side is you wil be running at 3500 rpms @ 70mph.
  11. BoogieDown
    Tampa FLA
    i'm going w/ the DX tranny cuz of price and theres so many. might be a dumb question but do i need JDM spindles and do i need all the brake parts too or can i use mine. i'm geting tax refund soon so its time to shopin for pieces parts
  12. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    spindles are the same and brake parts should bolt up
  13. Projectzc
    Projectzc Senior Member
    I would not suggest useing a DX 4 speed it will suck. Maybe a DX 5 speed or LX 5 speed. What good is an Si tranny or the very best is get an Si and ZC tranny and swap the final drive so you got low rpms in 5 gear but the nice quick ZC 1-4 gears. Oh and not ZC trannys come with and LSD. If you use a ZC tranny you need different axles two same sized cause the ZC has an intermedate shaft. I think 88-89 Teg axles will work.
