ZC Swap?!?
Discussion in 'HYBRID -> EG-EK / DC' started by soundwave528, Jan 2, 2008.
  1. soundwave528
    soundwave528 New Member
    i'm looking for all the info on this swap that i can. found alot actually. just havent found a write or anything about it into the eg chassis. i have a 93 dx hatch 5spd hydro tranny. stock motor. heard that the tranny should bolt right up? and what about wiring? everything plug and play? i know i'm going to need the ecu and such. jsut trying to get everything sorted out. thanx to all who help
  2. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    just wondering but why would you choose the ZC? are you talking dohc or sohc??
  3. phunky.buddha
    Dallas / Fort Worth, TX
    If you stick with the SOHC ZC non-VTEC, you can basically just drop it in and run without any wiring changes.. if you want to. The transmission, mounts and pretty much everything else will bolt right up. The fuel map may be wrong, but it'll be close- and if you have the time and cash, you can use Crome or Uberdata (or Hondata) to flash the ECU to something more suitable to that engine.
    SOHC ZC VTEC (basically a D16Z6) can work too, just add VTEC wiring and an ECU that's built for it.
    DOHC ZC will take a little more work.
  4. soundwave528
    going with the zc cause its different and i just like to be that person and its on the cheap end of things. looking at the DOHC zc. thanks for your replies :)
  5. philyphreak2127
    Littleton, co
    well if you wanna be unique then you have indeed chosen the right motor.
  6. soundwave528
    calesta, got anymore info for me about the dohc? ^_^
  7. phunky.buddha
    Yeah- it's not worth your time if you're thinking of dropping it into an OBD1 car. The D16Z6 will be just as good, cheaper to find and install, and has much better aftermarket support.
  8. juba allen
    juba allen New Member
    i have a sohc zc, in my 96 dx HB. It's not running well. what ECU should i use. Thank You
  9. makewheelies304
    makewheelies304 New Member
    ohio
    i got a mint dohc zc motor that is obd 1 id sell ya for 600 got it from hmotors last year....decided to go b series so im selling
  10. jonboy330
    jonboy330 New Member
    pensacola,fl
    hell if they dont buy it i will
  11. makewheelies304
    ohio
    first come first serve brotha, also have a si cable trans for another 140 and has no grinds and shifts like butter
