ZC swap
Discussion in 'HYBRID -> ED-EF / DA' started by BoogieDown, Mar 29, 2004.
  1. BoogieDown
    BoogieDown Senior Member
    Tampa FLA
    i have a 88 civic hb thats a 4 speed manual and i looked and that tranny came in the 87 hb. the vin says its an 88 but why the 87 tranny? will i still be able to do a ZC swap?
  2. CRX_B16B
    CRX_B16B Senior Member
    whats the year on your chassis vin?
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    does the transmission say L3 on it? if it does then it is 88-91 - the 88 Civic STD hatch came stock with the 4-speed L3 transmission
  4. BoogieDown
    Tampa FLA
    the chassis vin is ed6 it is a 88 i just checked i was looking at the mitchell on demand at work and had no 4spd listing for 88 so i got worried sorry
    where is the tranny code stamped?
    and can i still use my stock tranny or should i use a 5speed ? if so will i need new hubs struts ect?
  5. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    if its a 4 spd im pretty sure you have to usea different tranny probably an si or a zc tranny.. and also swap out the hubs or get custom axels :huh:
  6. Projectzc
    Projectzc Senior Member
    It will work for a ZC swap but I suggest you get a Si or a DX 5speed. You may have to up grade the spindels and the axles but I am not sure. A quick comparison will solve that
  7. BoogieDown
    Tampa FLA
    since the gearing is tall on the 4 speed would that be good for a turbo?
  8. BoogieDown
    Tampa FLA
    what spindles will i need and other misc peices parts do i need? can i use my brake parts? control arms?
