You dont wana do that man. Just adapt your existing harness. I just did the swap and it may be kinda intimidating but if you take it one step at a time its cake. Or just cut the injector harness portion off of the SI harness and go from there. That might be do able but you cant just plug a SI harness into a DX car. Good luck, check out www.fourthgenhatch.com for info on the swap. Take it easy and good luck agian.
