zc tranny on d15b block
Discussion in 'Civic and del Sol - EG and EK' started by joker01, Sep 3, 2012.
  1. joker01
    joker01 Member
    caribbean, St.Lucia
    sup guys been a while sigh miss this forum and am trying to do a auto to manual swap and i got parts from a donor car except the tranny and i sourced out one but its from a dohc Zc and i was wondering will it bolt up and work properly and would d15b axles work
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    won't work - to use the DOHC ZC transmission, you must use the ZC intermediate axle shaft and larger equal length Integra type axles - the unequal length D15B axles, where they go into the transmission, are smaller diameter than the ZC axles - you can't use the ZC intermediate shaft as the D15 doesn't have the threaded holes on the back of the block to bolt on the ZC intermediate shaft
    are you sure it is a DOHC ZC transmission?
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Or you can try to make a hybrid axle by using the inner cup of the intermediate shaft and the rest of the long axle...
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There's a company that makes a kit(I forgot their name, but they build hydro conversions for cable cars too) to use a ZC intermediate shaft on non-threaded blocks(D16Y and D15 blocks); I actually have one but probably will not use it. LMK if you're interested.
  5. jlicrx
    Colorado Springs
    from your post on d-series.org:
    Just look up "Hush Performance" on FB
  6. K2e2vin
    Raleigh, NC
    Haha, yeah that's them!
  7. t0ny gl0ws
    t0ny gl0ws New Member
    i am having this same problem but in reverse...i have a dohc zc motor wit a d15b tranny and the holes in the tranny for the axle is bigger lik a b series, also when i had my zc tranny i had un equal length axles, and now wit the d15b tanny im trynna use the same ones and there too small. i bought new single axles and there the same as the "zc" axles i had in and they dont fit into the d15b tranny either
  8. Posef
    Posef New Member
    i wa swoundering if u still have that zc trans and if u wanted to trade or sell it i currently have two single si trans and am trying to get a zc trans
  9. t0ny gl0ws
    i was reading a thread u were commenting on back in 09 while i was reasearching about my problem and i was wondering if u could help me...i have a dohc zc motor wit a auto zc tranny, the zc tranny had unequal length axles in it, the tranny went and i got a d15b tranny and everything bolted up fine. as soon as i go to put the original axles in i had they were too small in diameter so i went and bought single axles and i have the same problem, the hole in the tranny where the boot and head goes in is bigger in diameter then the single axles. its lik i need b series axles in the d15b tranny??? at the end of the day my main question is what axles go into a auto jdm d15b tranny cus stock single axles dont work
  10. t0ny gl0ws
    sorry for using ur thread for my problems but im having a similar problem and this site wont let me post my own thread cus i jus joined it, i applogize jus tryna find some answers
  11. phunky.buddha
  12. t0ny gl0ws
    idk if u were asking me but i have a zc traanny but its auto and the caseign is cRAcked, its all messed up
  13. t0ny gl0ws
    is tht the answer thou? are u saying tht all i need is b series iners on single axles? the teeth match up and everything
  14. phunky.buddha
    That's how a lot of people make hybrid axles to adapt a certain transmission to different hubs. As long as the lengths are good, you can do it. Between axles of the same make/chassis, a lot of times the CV guts will fit into different axle cups.
  15. t0ny gl0ws
    alright ima try this i have a extra set of b series axles so ill see thanks everyone for the help
  16. phunky.buddha
  17. t0ny gl0ws
    the passenger side worked out fine but the driver side dosnt fit on the axle and idea what axles i needa use for the long one?
  18. Posef
    Posef New Member
    ihave a pair of cv axles from my dohc zc
  19. K2e2vin
    Raleigh, NC
    D-series axle with the B-series CV joint on the inside.
    What I did with mine intially was just swap over a D-series differential(40mm Si/EX), along with FD, and just ran stock D-series axles.
