I wanted to know does a Jdm zc cable tranny bolt to a JDm d15b vtec engine obd1? Since you have to run the half-shaft with the zc trans will it bolt to the back of the Jdm d15b?
Quoted post[/post]]
It will not work; as stated before, you will have issues with the one-bolt. You can do what I'm doing; which is put in a differential from a Si/EX transmission that will allow you to run the uneven length axles.
