zc tranny?
Discussion in 'HYBRID -> ED-EF / DA' started by 91crx, Sep 7, 2004.
  1. 91crx
    91crx Senior Member
    Do i use the 90-93 integra axles or the 86-89 integra axles for the zc cable tranny, also do i have to use dx or si hubs for it as you do with the b series trannys thanks
    brett
  2. 91crx
    91crx Senior Member
    alos can i use the si clutch and flywheel?
  3. phunky.buddha
    Dallas / Fort Worth, TX
    90-93 axles with the ZC intermediate shaft, DX or Si hubs.
    You can use the Si clutch and flywheel if they match the year of the transmission. 88 has to go with 88, 89-91 are all interchangeable between each other.
  4. wiredjosh
    wiredjosh Member
    loovull, ky
    I used the d-series flywheel, but mine required a 92-95 clutch, so make sure which one you need before you order! The splines were different on mine from the 8-91 Si...
  5. 91crx
    91crx Senior Member
    where can i get the zc intermediate shaft?
  6. 91crx
    91crx Senior Member
    i alos heard that i can use stock crx axles if i dont use the zc inetrmediate shaft is this true?
  7. 88bluehf
    88bluehf Senior Member
    Denton,TX
    dont believe so(si axles) believe its a diff spline ....you need a zc intermediate shaft. ive been told and have read on multiple forums that nothing else will work.
  8. krazywhitboy
    krazywhitboy Member
    you can also use a 88-89 integra intermidiate shaft but you have to cut the top bolt off.....
  9. wiredjosh
    wiredjosh Member
    loovull, ky
    I am using 90-03 axles and intermediate shaft w/ my ZC trans. Works good.
