ZC tranny
Discussion in 'HYBRID -> ED-EF / DA' started by benfx666, Aug 26, 2005.
  1. benfx666
    benfx666 Junior Member
    Hi, i have a d16 obd0 with automatic tranny with a pg7 obd0 in my civic 90
    my problem is : the reverse on the tranny is broken...and i have on my hand a
    zc tranny obd1 Automatic with midshatf.....
    I want to know if i can do the swap or i need to change the ecu
    and i want to know for the axles
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    SWAP IT..
    you will need the 90-93 teggy axles.
    Or, put a standard in that bastard while you can.
  3. benfx666
    thank for this info ,
    on my 0bd0 tranny i have only 1 connector the AT Lockup control solenoid valve
    now, on my 0bd1 zc tranny i have 2 connector....the 2p AT Lockup control solenoid valve and the 3p speedometre sensor connector
    what i do whit the speedometre sensor connector????
