Well, you should be able to just take the HF final drive and counter shaft, then install them in place of the ZC's- but unless you're doing it because you have all the parts already and need to get a transmission back in service, I wouldn't do it. Keep the ZC final drive if you can, or swap in an Si final. Shorter gearing = better.
