ZC w/ 1.5 head
Discussion in 'Engine Building' started by liqmysak, May 25, 2005.
  1. liqmysak
    liqmysak Junior Member
    ok i have a 1990 CRX that i bought with a ZC swap but all the information that i'm finding about the ZC says its a 1.6 ....well what's getting me is that my motor has a 1.5 head on it cuz the plugs are on the top...so i'm curious now if ZC makes a 1.5? or if its just a 1.5 head on the 1.6 block...an if it is that, what would be the purpose of that? is it better compression or sumthing? i can't find any information about this anywhere so hopefully sumone here can help me out...thanx
    ps- 1.5 head on 1.6 block......ugh i don't get it but the car moves...
  2. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    What zc you talking about, the dohc?
  3. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    there are zc's that are 1.5...its the equivalent to the d16a6 with a lil more hp...there is also a 1.5 zc with vtec as well..now...this is what you cannot do...use a DOHC bottom end and an sohc head with out modification...and vise versa....thezcr.com ownes all
  4. liqmysak
    its sohc 1.5 head... the block says ZC..so i figured it was a 1.6...sorry imma honda beginner
    so they make a 1.5 vtec? if it was a vtec would it say it on the valve cover? or what would defanitely tell me that it is? when i rev it up past 4 it kinda sounds like it could be...but its also got that destinctive crx sound too so i'm not fur sure
    theres pix at http://ridinlo.cjb.net of my rex if it'll help you out at all...an thanx fur ur help to...i appritiate it :-D
  5. bklyneg
    bklyneg Senior Member
    los angeles
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    It is not :)
  7. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
  8. xj0hnx
    C.C.TX.
    ZC Info
  9. tonycrx
    tonycrx Junior Member
    i have a 1990 crx with the same swap it is hard to cross reference the parts but most si sohc parts work fine its been running for over 3 years with no problems just dont blow the dissy $400 to replace if you can find it
    i dont have any real pics but you can see alittle at www.geocities.com\jdmmazz
    good luck hit me if you have any questions
