Zex + Window Switch = install
Discussion in 'ECU's, Electronics, and Tuning' started by ChrisSiR, May 11, 2004.
  1. ChrisSiR
    ChrisSiR Senior Member
    Got that figured out....
    hope this makes sense... thanks for any info in advance
  2. ChrisSiR
    Now, new question... where can i find an RPM signal? b16a pr3 aut ecu....
  3. pissedoffsol
    pinouts are in the reference section hommie
  4. ChrisSiR
    Thanks man, for some reason, i always forget that thats up there...
    Is it the Speed sensor i want? (pin b16) or am i lookin for something else?
  5. pissedoffsol
    i don't know exactly what you are trying to do.. but to me, you'd only want the nitrous on at wide open throttle...
    so, id hook it up to the TPS
  6. ChrisSiR
    well, the window switch is being used to spray the nitrous after i get traction on a launch... ive got my launch technique down, just need that extra umpf to get to vtec... (that and to save me from bouncing off the lim while spraying)... the zex kit uses the tps, for WOT spray.... so in other words, it wont spray unless im above a certain RPM, WOT, and Armed.... thats what im trying to do...
    So, which wire am i looking for?
  7. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    imo, you shouldnt use it so soon...wait till a taller gear
