I have a 03 CRV. The check engine light came on and the OBDII code reader stated no activity from the O2 sensor, Code P0134. I've discovered the CRV has a front and rear O2 sensor. How do I go about finding out which sensor is the bad one? Any help would be much appreciated. Thank you.
#2 | |
^^ Likes Bewbies
Ride: Rex, Yamaha Virago, CB900F Supersport
If it was me, I would start with one. Get a new O2 sensor, and replace the front one first, and if the code still persists, than change the rear. That way you only buy one sensor. If you replace the front one and the code still persists, than you know it's the rear one, and the front one is still functional and working. Just use that one on the rear.
| Map sensor question | tuner2484 | Forced Induction | 3 | 08-22-2008 09:10 PM |
| MAP Sensor Question | kylelohrenz | HYBRID -> ED-EF / DA | 3 | 04-08-2007 09:25 PM |
| IAT sensor question(s) | mdlax1 | ECU's, Electronics, and Tuning | 2 | 04-28-2005 12:40 AM |
| o2 sensor question | Tonyd0821 | General Tech and Maintenance | 4 | 04-05-2004 04:15 PM |
| O2 sensor question | 95preludetypes | General Tech and Maintenance | 0 | 09-28-2003 07:08 PM |
