Go Back   HondaSwap Forums > Model Specific > Trucks and SUV's
Honda Ridgeline review and info
Old 06-24-2006, 01:04 PM   #1
...PENDEJO....
BodyDroppedNikes's Avatar
Ride:  bagged Ford Ranger Splash
Rep Power: 202 BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
Send a message via AIM to BodyDroppedNikes Send a message via Yahoo to BodyDroppedNikes myspace
Default Honda Ridgeline review and info
A pickup truck has been the missing link in Honda's U.S. lineup. It's easy to understand why this is the last major segment for the cautious automaker to dip a tire into. Having no V-8 engines, solid rear axles, or body-on-frame vehicles among any of its other offerings, Honda couldn't readily do a traditional-style pickup. So it had to do something different. Now it has. Honda claims it started with a clean sheet of paper, but it was one with the faint outline of the Pilot on it. Like the Pilot, the new Ridgeline pickup uses unibody construction, a transverse-mounted 3.5-liter V-6, and four-wheel-independent suspension-not typical pickup hardware. The Ridgeline also defies convention in that it offers only one cab configuration (four-door), one bed length (five feet), and one powertrain (a 24-valve SOHC V-6, five-speed automatic, and on-demand four-wheel drive).
The result is a pickup with better-than-expected towing, payload, and off-road capabilities. It has a spacious interior, very good ride and handling, and some interesting cargo-hauling innovations.
Because the Ridgeline's independent rear suspension takes up far less space than a live axle, Honda was able to add a large compartment under the truck bed, providing a clean and dry home to the spare tire (either the standard mini-spare or available full-size) and, more significant, an 8.5-cubic-foot trunk. At last: secure, weatherproof, outside-the-cab cargo space in a pickup. The volume might not sound like a lot, but the ultra-practical box shape allows it to swallow even a giant-size cooler-or, with its waterproof periphery and built-in drain plug, it can be used as a cooler itself.
Cargo beds in 4x4 pickups have gotten pretty high off the ground, and although Honda's underfloor storage doesn't raise the Ridgeline's much farther, owners would need telescoping arms to reach over the dropped-down tailgate to get anything out of that new trunk. Honda's solution, borrowed from station wagons of yore, is a two-way tailgate, which drops down or swings open like a door to allow easier loading of the trunk or of the bed itself. (It's also particularly neat for hosing out debris.) Despite the unconventional hinge arrangement, the lowered tailgate can support 300 pounds when hauling.
On the subject of the cargo bed, we should mention that with 49.5 inches between the wheelhouses, the Ridgeline is the only midsize pickup in which 4x8 building materials can lie flat on the floor. They do stick out
the back, though, as there's no GM-style mid-gate to extend the cargo box. At 6.5 feet with the tailgate lowered, it is long enough to carry a dirt bike or an ATV, however, and it offers a respectable half-ton (1100-pound) payload capacity.
The cargo box is not a separate unit but is fully integrated into the rest of the body. The resultant increased rigidity is evident in the absence of shudder over bumps, an affliction that plagues most 4x4 pickups. The independent rear suspension also contributes to the composed ride. Body control is good, even with a full load, and the Ridgeline stays relatively flat in corners. The firm-feel steering is appropriate for a big truck and is pleasantly free of slop. Stability control and four-wheel disc brakes with ABS are standard, though grippier tires would help both handling and braking.
Honda engineers claim that more than 90 percent of the Ridgeline's chassis is different from the Pilot's, and some of those changes-two additional crossmembers (seven total) and fully boxed frame rails-help explain the Ridgeline's rather porky 4500-pound curb weight. It's no wonder the 255-hp V-6 doesn't send the Ridgeline charging onto the freeway, although Honda claims it will get to 62 mph in 9.5 seconds, which would put it about on par with a V-8 Dodge Dakota but behind a V-6 Nissan Frontier or a Toyota Tacoma. The Pilot's five-speed automatic has been extensively reengineered for pickup duty, helping to give the Ridgeline a 5000-pound towing capacity. That figure isn't the highest in the mid-size class, but it's probably enough for most people.
Likewise, the Ridgeline's 8.2-inch ground clearance and lack of a low range for its four-wheel drive might elicit snickers from off-road extremists, but we were able to bash bumps and tackle steep climbs and water crossings without incident. Wheel travel of 7.3 inches front and 8.2 inches at the rear is better than you might expect from an independent suspension, and Honda's VTM-4 lock button allows the driver to send the maximum torque (70 percent) to the rear axle at low speeds, such as when pulling a boat up a ramp.
To reinforce the message that this really is a tough truck-not some kinder, gentler pansy pickup-Honda designers gave it an exterior that looks as if it were designed with Lego blocks. The all-new interior features oversize matte silver knobs, a huge speedometer, and meaty door pulls (the better to distract you from the hard plastics everywhere else in the cabin). The cabin is sprawl-out comfortable front and back, and there's storage space everywhere. The center console alone is so labyrinthine you could easily lose a Big Mac in there for weeks.
Honda has created something truly different in the world of pickups, an area that has seen lots of one-upmanship but very little critical thinking. The Ridgeline is not designed to establish bragging rights but to meet real needs-which may be its most unusual aspect of all.
source: 2006 Honda Ridgeline Engine, Towing Capacity - Road Test & Review - Automobile Magazine
engine specs:
engine type: 24-Valve SOHC V6 VTEC with multi-port fuel injection
displacement: 3471 cc
horsepower: 247hp at 5750 rpm
torque: 245 ft/lbs at 4500 rpm
redline: 6300 rpm
bore and stroke (mm): 89x93
compression ratio: 10.0:1
CARB emissioms rating: ULEV-2
transmission specs:
gear ratios:
1st: 2.693:1
2nd: 1.566:1
3rd: 1.023:1
4th: 0.729:1
5th: 0.531:1
reverse: 1.889
final drive: 4.533
variable torque management 4-wheel drive system
locking rear differential
5-speed automatic
heavy-duty automatic transmission cooler
chassis/suspension/body:
closed box frame with uni-body construction
fully boxed high strength steel frame rails and crossmembers with internal stiffening
steel reinforced composite cargo bed
MacPhearson strut front suspension
multi-link rear suspension with trailing arms
front and rear stabilizer bars (mm, front/rear): 23.0/25.4
variable power assisted rack and pinion steering with cooler
steering wheel turns (lock to lock): 3.38
steering ratio: 18.5:1
turning radius (ft): 42.6
power assisted ventilated front disc/solid rear disc brakes (in): 12.6/13.1
wheels: 17" styled steel or alloy depending on trim level
tires: 245/65/R17 105S all-season tires
trim levels: RT, RTX, RTS, RTL
source: http://automobiles.honda.com/models/...Name=Ridgeline
***Please leave this section blank. For office use only.***
-BrianE.
1995 Ford Ranger Splash
2009 Ford Focus
http://midwestminis.forumotion.com/forum.htm
Originally Posted by MthaFuknGreen
noo... pole like the things strippers are on.
(id say like your mom is on, but i dont wanna get banned.. lol)
BodyDroppedNikes is online now   Reply With Quote
Old 08-31-2006, 04:51 PM   #2
Watanabe Whore!!!
Airjockie's Avatar
Ride:  datsuns & Subarus
Rep Power: 217 Airjockie has a reputation beyond reputeAirjockie has a reputation beyond repute
Airjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond reputeAirjockie has a reputation beyond repute
Send a message via AIM to Airjockie myspace
I didn't know it can tow 5000 lbs....
I think I'm going to go test drive one now....
Airjockie is offline   Reply With Quote
Old 08-31-2006, 04:54 PM   #3
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
Rep Power: 266 get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
i have seen a few of these with 20 and 22 inch rims rolling around. they are pretty clean. i definitely don't look at it like a hardcore 4X4 like i do an F350 or anything though.
I changed the page layout. let me know what you think. I need feedback.
www.obamacies.com
get_nick is offline   Reply With Quote
Old 08-31-2006, 05:20 PM   #4
Watanabe Whore!!!
Airjockie's Avatar
if the price was in the 19K's area...I'd jump on it..but damn if I'll get stuck with a $5-600 payment a month for one...
but I am thinking of something new....and winter is getting near and the AWD or FWD does sound tempting...and the thought that I can get a trailer and tow my cars to the tracks to have fun doesn't sound bad....
Old 10-02-2006, 11:20 PM   #5
Rep Power: 0 torch26 is on a distinguished road
LoL if u like it! its well worth the payment it even smokes tiburon's with 5 people and stuff in the back lol "personal experance" and for heavy duty its very close to a 1500 or 1/2 ton truck a newer one,, this truck has gone ferther then even i expected and i had hight expectations from it being a Honda and all.. Later
torch26 is offline   Reply With Quote
Old 10-15-2006, 05:59 AM   #6
amborghini's Avatar
Rep Power: 17 amborghini is a glorious beacon of lightamborghini is a glorious beacon of lightamborghini is a glorious beacon of lightamborghini is a glorious beacon of lightamborghini is a glorious beacon of light
theyre nice trucks. def. high priced for what they are. i love the storage in the bed. thats badass. you can load it with ice and pack it full of beer. lol. (iowan redneck girl talkin) i took it for a test drive and it def wasnt very fast getting on it and i tried takin it for jumps.lol. it drives like a cadi. it took the jumps very smoothly i might say. lol. i dont recomend trying to jump a ridgeline at your local dealership. lmao
amborghini is offline   Reply With Quote
Old 12-13-2006, 02:56 AM   #7
Ride:  89'240sx, 91civic2dr,92civic4dr
Rep Power: 7 adonis is on a distinguished road
Send a message via Yahoo to adonis
Default one quik question
i,ve found one wrecked in a junk yard near my house anybodie ever think of a swap the engine looks huge but mostly plastic dont know what it would fit in maybe to much fab work idunno peaple put v8 in hondas why not a honda v6
adonis is offline   Reply With Quote
