Go Back   HondaSwap Forums > Model Specific > Trucks and SUV's
question about the '10 pilot engine
Old 09-15-2009, 04:53 PM   #1
Ride:  building: ek h22
Rep Power: 1 necessaryevil is on a distinguished road
Default question about the '10 pilot engine
ok so i saw an ad for the new '10 pilot the other day and thay where saying it can run on 3 cyl, now i know this tech. has been around for a while now but have yet to figure out how it works? so my question is this: what engine is in the pilot and how do thay shut off the cylinders?
necessaryevil is offline   Reply With Quote
Old 09-15-2009, 06:21 PM   #2
AHHVTEC's Avatar
im guessing they stop the fire from going to that cyl by the ecu/computer
Old 09-15-2009, 07:14 PM   #3
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
Honda V6
As far as we are aware, there’s only one mass produced Japanese engine that employs cylinder deactivation – the Honda J-series V6.
For the 2005 model year, Honda introduced its Variable Cylinder Management (VCM) system to the 3.5 litre Odyssey and 3.0 litre Accord Hybrid. For the 2006 model year, VCM is also likely to appear in the Honda Pilot soft-roader.
Honda’s VCM system deactivates an entire bank of cylinders at light load – the engine switches from 6 to 3 cylinder operation. Road speed, rpm and throttle position are the major factors used determine when the engine switches to 3 cylinder mode.
Deactivation of cylinders is achieved by releasing a synchroniser pin that normally interlocks the cam follower and rocker arms. The synchroniser pin is released using hydraulic pressure which is controlled by a dedicated solenoid. Once the synchroniser pin is released, the cam follower continues to move against the camshaft but the rocker arms and valves remain in a closed position.
It is said that 3 cylinder operation remains smooth (though not quite as smooth as in 6 cylinder mode) and Honda has done a great job calibrating the electronic throttle system for a seamless transition. Actively controlled engine mounts are also employed to reduce the sensation of cylinder switching.
Interestingly, the VCM-equipped Odyssey and Accord Hybrid also feature an Active Noise Control (ANC) system that uses the audio system speakers to cancel undesirable engine boom during 3 cylinder operation. The ANC controller uses 2 microphones inside the cabin and generates an out-of-phase signal to cancel out the sound waves. ANC is not used during 6 cylinder operation.
The J30 3.0 litre VCM engine of the Accord Hybrid generates 179kW (plus 12kW from its electric motor assist) and delivers 23 – 43 percent better fuel consumption than a conventional Accord V6.
The Odyssey’s J35 3.5 litre VCM engine puts out a considerable 190kW and returns fuel consumption around 11 – 12 percent better than the non-VCM version.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 09-17-2009, 12:02 PM   #4
god i would hate to have to hunt down a fault in all that computer controled mess
but thank you for the info
REMOT ENGINE START ALARM Civic Accord Pilot Fit S2000 M RSS-Bot Auctions 0 11-21-2008 06:03 PM
REMOT ENGINE START ALARM Civic Accord Pilot Fit S2000 M RSS-Bot Auctions 0 11-21-2008 03:17 PM
REMOT ENGINE START ALARM Civic Accord Pilot Fit S2000 F RSS-Bot Auctions 0 11-21-2008 02:50 PM
REMOT ENGINE START ALARM Civic Accord Pilot Fit S2000 F RSS-Bot Auctions 0 11-20-2008 02:03 PM
2010 honda pilot question Tsing Tao Trucks and SUV's 3 09-16-2008 07:28 PM
