90 si rear discs
Old 04-13-2008, 11:28 PM   #1
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
Rep Power: 18 90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light
Default 90 si rear discs
i found a 90 teg thats smushed to nothing (In the front) and i want to put the rear discs on my 90 civic si. i found this website that tells me mostly what i need except i thought i had to use the booster and master cylender off the teg .do i if i'm using the stock discs on the front of my si?
this is what i found.
FourthGenHatch
90civicboy is offline   Reply With Quote
Old 04-15-2008, 12:22 AM   #2
Rep Power: 7 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
you should, but dont have to. get the proportioning valve off the teg if you can, that's more important than the master cylinder and booster.
BrokenRex is offline   Reply With Quote
Old 04-15-2008, 10:27 AM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 291 E_SolSi has a reputation beyond repute
upgrading the cyl and booster will give you a stronger pedal
not NEEDED but definitely nice
same goes for the prop valve
Originally Posted by Celerity View Post
E has a way with words, a way that should be reserved for beer ads and television show / movie premiers.
"Stop horsing around with that complete childish batshit that you call <insert competitor product name>. Grow up and be a fuckin man and buy <insert product name>. If you don't, you might as well squat to pee, candy ass"
"My name is E, and I approve this message"
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 04-15-2008, 02:48 PM   #4
he's right about the pedal, because a larger master cylinder will move more fluid per unit of travel at the pedal. the converse is true also, a larger piston in your caliper will require more fluid to move, and require more pedal movement to get the same distance traveled as the smaller piston.
the proportioning valve however, limits fluid to the rear brakes, to keep the balance of front/rear braking. a wheel cylinder and a caliper require very different amounts of fluid to get the same clamping/expanding force. this will have no noticeable effect on pedal travel or feel.
Old 04-15-2008, 05:35 PM   #5
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
alright i'll get all of thoes things , but just one more question, in the integra rs ls and gs do they use all the same brakes? because i was wondering if the gs might have bigger brakes.
Old 04-15-2008, 11:49 PM   #6
E_SolSi's Avatar
pretty sure they are the same
МОΛΏΝ ΛΑΒΈ
Old 04-16-2008, 09:55 AM   #7
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 92 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
^yep...so basically if you get the prop valve,master cyl and booster,,you will stop on a dime...youll be quite pleased id have o say
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now   Reply With Quote
Old 04-18-2008, 02:37 PM   #8
The Pussi Snatcher
Ride:  90 Ls/Vtec Turbo Da
Rep Power: 3 90DATeggy is an unknown quantity at this point
Send a message via AIM to 90DATeggy Send a message via MSN to 90DATeggy Send a message via Yahoo to 90DATeggy
90-93 are all the same i have all 3 years "90 da 1 is a 4door and 91 is a coupe "93 is a gs-r coupe i converted
IM LOOKING TO GET A MSD 6AL box for local pickup only
Looking FOR LS MESH wheels Pm Me If U GOT THEM
IM LOCATED IN ORLANDO..PM ME IF U GOT IT
Owning a type-r is just like every other honda that is modded in Orlando,FL you wake up and its Gone....Whammm
If you find anything I say helpful, please leave me some rep...
90DATeggy is offline   Reply With Quote
Old 04-18-2008, 02:41 PM   #9
I DonkeyPunch Hypocrites
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 92 BMW 318is
Rep Power: 107 B16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Just use the master cylinder from a 91 ex civic. It'll bolt to your stock booster perfectly and it's a 15/16... save yourself the time from switching out the booster. Make sure you also get the non abs 40/40 prop valve from the integra...
Now that Obama, a (half) Black man, is the President, I don't want to hear anymore about this so-called 'man' who's been holding your lazy ass back. Go get a damn job...
B16RacerN2NR is offline   Reply With Quote
Old 04-18-2008, 08:16 PM   #10
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
where do i look fo the 40/40 stamp on the prop valve? would it be visible from looking at it in the car, in otherwords are you braindead if you cant see it right away?
Old 04-18-2008, 08:32 PM   #11
Ride:  Still waiting.
Rep Power: 0 eggo831 is on a distinguished road
Send a message via AIM to eggo831 myspace
It should just be stamped on there. Feel around to feel ridges.
eggo831 is offline   Reply With Quote
Old 04-19-2008, 08:50 PM   #12
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
well i went and got them today, sort of. it figured he had abs so i couldn't take the prop valve and MC/booster, i'll have to get them off another car, i'll be looking. he also had momo ajustable lowering suspension, should i take it?
Old 04-19-2008, 08:55 PM   #13
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
what about a '91?
Old 04-19-2008, 08:56 PM   #14
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
whats a ex? i live in canada so they dont exist. what motor do they have?
Old 04-20-2008, 12:11 AM   #15
wow, that guy painted ONE dust shield and ONE caliper. those might not be from the same vehicle... me and my over-observant insanely obvious observations.
Old 04-20-2008, 12:18 AM   #16
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
he said the painted one is from the factory never been removed from the car, and the other is from a '93 rs. PLEASE dont tell me i f**ked up. before he piled it he JUST put new rotors and pads on it i'm going to take em apart and clean everything up and paint just the calipars red. is that a ricer thing to do?
Old 04-20-2008, 12:30 AM   #17
Honda Civic - Wikipedia, the free encyclopedia
I don't know what you guys call your EX's out there... I think Si's
Old 04-20-2008, 01:05 AM   #18
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
the only 4g civics we have in canada are the CX DX and Si (hatchback). CX is very, very basic, dx is a bit more nicer (CX and DX have D15b2 engines) and si (d16a6) we also have the sedan only in DX and LX (D15b2) and the wagon which is only 2 wheel drive and D15b2 (i think might be 4wd and D16a6 i've never seen one) i know the '92-'95 civic ex is si in canada and the '96-'99 civic ex is si in canada. and in canada the sir is your si. its very confusing, i know
Old 04-20-2008, 10:57 AM   #19
you didn't do anything wrong, however no dust shield/caliper is painted from the factory on these cars. some paints can actually impede the calipers ability to shed heat. i don't paint any for that reason, but most aftermarket calipers are painted from the factory. brembo, willwood, spoon, alcon, etc. so the heat issue probably doesn't outweigh the benefit of no rust. sometimes form follows function, in this case, maybe function isn't effected much, or at all.
Old 04-20-2008, 03:32 PM   #20
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
just checking, thanks yalll
Old 04-20-2008, 10:14 PM   #21
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
i got them in today, everything went well all the bolts fit and i only broke 1 bolt, not too bad i say. the e brake locks on gravel up well, ,i could never do that with drums. i cant really feel them yet so i am looking for a prop valve and MC/booster, they should be awesome
Old 04-21-2008, 04:21 AM   #22
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 101 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
I did this conversion on my EF but I didnt do the prop. valve or MC or booster and you can really tell it stops better compared to drum.
Looking for a P28 and B-series turbo parts, PM me.
Old 04-21-2008, 10:16 AM   #23
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
