'91 sedan 13" rims with lip??
Old 08-31-2009, 08:43 PM   #1
Senior Citizen
91civisedaner's Avatar
Ride:  1991 civic sedan 1972 datsun 620
Rep Power: 3 91civisedaner is on a distinguished road
Default '91 sedan 13" rims with lip??
I have a '91 sedan,and I'm buying 13" enkei 92s with a big lip. i think their 13x6 or 7.anyone rolling a setup lke this?? I'm gonna roll 175 50 13 to tuck them or 185 60 13s will i have to roll the fenders?? Help Please!! i appericiate ANY info!! THANKS
91civisedaner is offline   Reply With Quote
Old 08-31-2009, 09:22 PM   #2
Ride:  CIVIC
Rep Power: 0 hooligan is infamous around these partshooligan is infamous around these partshooligan is infamous around these partshooligan is infamous around these partshooligan is infamous around these parts
Whats the offset of the wheels?
running 175's would not make a difference b/c their only .4 inches thinner. If your tires are stickin out they may hit the fenders when you bottom out so see if you can put enough weight on the car to see if they will hit when the car bottoms out. It will probably will look better any ways with your fenders rolled if your wheels are stikkin out. Some reputation points would be nice
hooligan is offline   Reply With Quote
Old 08-31-2009, 09:28 PM   #3
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 383 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
its all depends on the offset..
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is online now   Reply With Quote
Old 08-31-2009, 10:18 PM   #4
Senior Citizen
their a 0 off set.I'd have more rep but I haven't been on here for a year
Old 08-31-2009, 10:28 PM   #5
Ride:  CIVIC
0 offset does not seem right b/c if they have a big lip they should have positive offset. It would be nice if you gave me some rep points is what i mean
Old 08-31-2009, 10:32 PM   #6
Senior Citizen
then i dont know the off set,they have a 2" lip and they stick way out of a 1985 toyota corolla fenders
Old 08-31-2009, 10:36 PM   #7
Führer Mod
eg6sir's Avatar
Ride:  Le Car
you got that backwards...
anyways.. w/ a 0 offset you'll need to add some camber to get it to tuck and roll the fenders possibly
XGT: cEElint
Old 08-31-2009, 10:38 PM   #8
Senior Citizen
i checked out some threads on here they appear to be +12 off set
Old 08-31-2009, 10:41 PM   #9
Führer Mod
eg6sir's Avatar
Ride:  Le Car
do you know how to measure offset?
read this
https://www.rsracing.com/tech-wheel.html#backspace
XGT: cEElint
Old 08-31-2009, 10:50 PM   #10
Senior Citizen
i can't measure them right now they have tires 205 60 13s and are still on the toyota i'm pickin' them up on wensday,I just wanted to know if anyone runs some thing similar and if I could tuck them, with a little tire stretch and rolled fenders,i'm not lookin' to go to low just enough to tuck a little,egr6 sir you had a post w/a eg w/some 15" 92s they look just like them but 13s
Old 08-31-2009, 11:13 PM   #11
Ride:  CIVIC
Honda wheels have around +40mm offset so you may or may not have a problem with +12mm offset which is around an inch difference. The 175mm tires actually may help.
I know what im talking about eg6sir Some rep points for me would be cool!
Old 08-31-2009, 11:17 PM   #12
Führer Mod
eg6sir's Avatar
Ride:  Le Car
sure.. but it'll be negative if you beg for it.. ... so, if you still want that rep.. i can give it to you or you can forget about it..
anyways, you're wrong still.. big lips will usually have a negative offset or a low positive offset
XGT: cEElint
Old 08-31-2009, 11:21 PM   #13
Ride:  CIVIC
please explain why civic wheels have around +40mm offset? He is getting +12mm offset which means the mounting surface is 12mm to the outside of the centerline which means they will stick out more. What part does not make sense?
Old 08-31-2009, 11:27 PM   #14
Führer Mod
eg6sir's Avatar
Ride:  Le Car
last time i checked Civic wheels didnt have a big lip.. hell, they dont have any lip
take a gander at this .. notice the wider the rim, the less chance that it'll be a positive offset wheel.. thats because wide wheels have a bigger lip usually
XGT: cEElint
Old 08-31-2009, 11:41 PM   #15
Ride:  CIVIC
The big lip has nothing to do with offset. It all depends on the mounting surface and were it is compared to the centerline of the wheel.
And that chart you have is backspace which is a different measurment than offset. Backspace is measuring the back edge of the wheel compared to the mounting surface.
Please do some research then you will see. I really should have at leas 100 rep points by now.
Old 08-31-2009, 11:44 PM   #16
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 227 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
And to the OP who cares, get some flare if need be, my friend is tucking a set of Axis OG Sans with the 3 inch lip and fender flares on his EK, looks sick.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 08-31-2009, 11:47 PM   #17
Ride:  CIVIC
And you don't change camber to fix offset eg6sir. If you do your gunna have change your front tires at least twice as much.
Old 08-31-2009, 11:50 PM   #18
My name is Byron.
efhondakid's Avatar
He said camber to get them to tuck, like the euro guys do.
^ (dont listen)
Old 09-01-2009, 12:10 AM   #19
Ride:  CIVIC
Camber, Caster, Tow. If your talking about that camber than he will be running on the insides of his tires( same thing happens when lowering cars) and the inside of the tire will wear out much quicker. It also will affect stearing if done to much. If thats what your talkin bout. sorry if its a different camber than what you are talkin about.
Old 09-01-2009, 12:16 AM   #20
Führer Mod
eg6sir's Avatar
Ride:  Le Car
first off... that chart shows offset.. in order to know what your offset is you need to know what the backspace is... you're the one that needs to do some research
it isnt the camber that wears out the tires quickly.. its the toe ..
anyways.... go back to school, learn to read.. then you can come here and try to argue w/ me
thank you... at least some of our members know how to read..
XGT: cEElint
Old 09-01-2009, 12:35 AM   #21
Ride:  CIVIC
I have a nice video for anyone that wants to learn about camber, caster, and toe. Please just watch the video and stop arguing. thanks
Old 09-01-2009, 12:44 AM   #22
Führer Mod
eg6sir's Avatar
Ride:  Le Car
first off, this discussion is about offset, not about camber.. the OP said he wanted to tuck... well, in order to tuck a +0 offset, or hell.. even a +12 offset .. he'll need to run more camber
XGT: cEElint
Old 09-01-2009, 12:55 AM   #23
Ride:  CIVIC
here is the website to explain offset, and backspace please read carefully to understand it.
https://www.rsracing.com/tech-wheel.html this should end this argument if you read and understand it.
Old 09-01-2009, 12:57 AM   #24
Führer Mod
eg6sir's Avatar
Ride:  Le Car
read this
wow.. you're a fucking bright one...
XGT: cEElint
Old 09-01-2009, 01:01 AM   #25
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
fucking tard
МОΛΏΝ ΛΑΒΈ
JDM EG Civic Sedan 92 - 95 "FERIO" Rear Door Garnish RSS-Bot Auctions 0 05-03-2009 11:17 PM
15" rim offset for EK sedan? spartan_327 Wheels / Suspension / Tires / Brakes 0 09-21-2008 03:21 PM
HRE 597R Wheels Rims 18" " iforged volk ssr axis dpe " RSS-Bot Auctions 0 04-08-2008 08:53 PM
itr 15" rims, gunmetal itr rims, integra type r wheel, RSS-Bot Auctions 0 03-11-2008 08:03 AM
18" Volk Rims/ Si Rims For Sale/trade! kptrulee Parts: For Sale/Trade/Wanted 3 03-23-2003 11:07 PM
