Ok just wondering if possible to swap out my drum breaks in my 92 hatch and convert them to 99 civic coupe rear disc breaks? if I can, would someone please refer me to a how too? Im still new at this Import scene.
[b]My bike is faster than all your CIVICS combined! |
B happy
Ride: dohc 95 egg
You have to have the spindles, rotors calipers, brakelines ( from 92-95 Si), and ebrake cables ( from 92-95 Si). They will swap right on to your trailing arms.
Doing it with just the spindles is a pain, and I would say your better off just getting the whole trailing arms, and bolting them on, but you'd still need the ebrake cables. __________________
Ride: 1995 Civic EX coupe
http://www.fourthgenhatch.com/reardiscswap.html
http://www.jdmvtec.com/5lugday2.html http://tjshondas.20m.com/rrdisc.htm That's what I've gathered so far. I'll soon be attempting the swap, from a 1994 GSR to a 1995 Civic Ex - I'll let you know how it goes. From what I can tell, the 4th gen, 5th gen, and 6th gen Civics all use the same rear suspension design, as well as the 2nd gen CRX, 2nd & 3rd gen Integras, and all Del Sols. some discs are bigger than others, though. all the parts that 92b16vx mentioned are must-haves. In addition, a lot of people recommend the rear disc proportioning valve (marked '4040'), and a few like to add a bigger master cylinder. |
Admin with a big stick
Ride: 2003 S2000
The 88-00 rear discs are all 9.5 inch solid rotors, regardless of model...
If you're going to replace the entire trailing arm, go ahead and change out the trailing arm bushings. It's worth the time and extra cash. Using the old broken ones will make the rear end of your car feel like crap. __________________
| Rear disc brake conversion... | Kajed Kreation | Wheels / Suspension / Tires / Brakes | 1 | 06-17-2004 02:32 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| Rear disc conversion | UDT | HYBRID -> BA-BB /CA-CD | 0 | 01-04-2004 04:33 PM |
| rear disc conversion trouble | twerker08 | Wheels / Suspension / Tires / Brakes | 3 | 11-08-2003 10:39 PM |
| 90 Civic Rear Disc Conversion | starboy869 | Wheels / Suspension / Tires / Brakes | 1 | 06-04-2003 06:32 PM |
