ABS brake pad swap
Old 08-07-2007, 10:43 AM   #1
Silverchild79's Avatar
Silverchild79 has a reputation beyond repute
Silverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond repute
Send a message via AIM to Silverchild79 Send a message via MSN to Silverchild79 Send a message via Yahoo to Silverchild79
Default ABS brake pad swap
so I've heard two schools of thought on changing the pads on an ABS car (a teggy to be exact)
should I release the bleed plug when I compress the caliper or leave it in like I would do on my non ABS ride
please to be telling me
kthankx
Silverchild79 is offline   Reply With Quote
Old 08-07-2007, 02:39 PM   #2
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
I just leave it in on my accord. (yes it has abs)I never had any problems
nootrac22 is offline   Reply With Quote
Old 08-07-2007, 03:12 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
you can leave it closed and just push it back into the reservoir
but you should be flushing out your brake fluid once a year (2 years max)
when you change the pads is generally a good time to do it
Old 08-07-2007, 03:48 PM   #4
bleeding out the fluid is probably exactly the same as on planes huh?
press brake peddle to the floor and hold
open bleed screw and look for bubbles
close bleed screw
repeat as required
yes?
Old 08-07-2007, 04:05 PM   #5
E_SolSi's Avatar
yeah pretty much
i generally open all of the lines and let gravity drain the system out
then refill with fresh fluid
leave the lines open until clean fluid comes out
close each line when clean fluid flows from it
then bleed the system until the fluid looks nice and clean and there is no air left in the system
i empty out the system first because i found it takes less time than if you keep diluting the shitty fluid thats in there
a speed bleeder would probly save a shit ton of time but i have been too lazy to pick one up
МОΛΏΝ ΛΑΒΈ
Old 08-07-2007, 06:20 PM   #6
thanks for the help
I just picked up a speed bleeder for $40 (thank you military discount)
should be a snap now
rear disk brake swap bluhatch95 Parts: For Sale/Trade/Wanted 14 09-29-2005 03:33 PM
SIR2 front brake swap seanjuan Wheels / Suspension / Tires / Brakes 6 09-24-2004 03:11 PM
EG/DC Brake Swap Kajed Kreation Wheels / Suspension / Tires / Brakes 2 07-27-2004 08:58 PM
Civic SI 99' engine and BRAKE SWAP to a CIVIC 93' r.2 HYBRID -> EG-EK / DC 1 11-15-2003 01:53 AM
front brake swap entone Wheels / Suspension / Tires / Brakes 0 10-06-2003 11:00 PM
