The crx's brakes are bad, i have to press the pedal all the way to the floor to get them to grab, so far ive replaced, front pads, rear drum pads, rear hydraulic wheel cylinder, had to make rear brake lines, fine no leaks-used a pipe bender, and also replaced the master cylinder, and the brakes still suck! I have bled all corners where no air comes out, what could this be? The only thing i can think of it the brake booster?
Any idea's?
DB8 450whp project...... |
RETIRED
def not the booster. the booster only assists your foot. if it was the booster, you'd know if, because you'd have to stand on th pedal to get it too move... unless your ARRRRnold. brake lines are like 2000 psi. lol
chances are, your rear drum is so far out of alignment, that the fronts won't grab like they should before the ppv sees the proper split. |
#3 | |
#5 | |
RETIRED
[/b][/quote] sorry, that post sucked in terms of english. ![]() lol anyway, what i was getting at, is that the rear drums on civics are supposed to be self-adjusting. unfortunately, they suck at this. put the drum off, and get in there and tighten 'em down. |
#6 |
I did the bench bleeding for the master cylinder, and bled all 4 corners til all the air was gone out of the lines.
What exactly do I tighten down in the drums? I.E: where?
#7 |
To get the shoes inside the drum you had to turn the self adjuster so it was in (retracted). Then upon use it will extend so the travel to contact and braking is short. Pissed off is saying to go in and manually adjust it out some so the drum just fits over the brake shoes.
I have had to do that on several cars though the years...... |
#10 |
Ok, those have been adjusted and the brakes are still shitty, they grab very close to the floor, i dont know what else to check, anyone have suggestions?
Also like i said previously all of the corners have been bled.
#12 |
loosen the bleeder, press down and hold brake, tighten bleeder, let up brake pedal, all of this with the master cyl cap off, re fill brake fluid in cylinder.
#14 | |
when bleeding you want to pump the brakes a few times and then hold the pedal firmly before opening the bleeder. then when you open it, dont close it til your foot hits the floor, o right before it hits the floor. do that about 2-3 times per corner in the proper order, and you should be good.
91 CRX si 95 Integra LS I DO NOT answer tech questions via PM. Use the forums!!! Quote:
get a free flatscreen, yes it works! Please give what you can to the Tom Cote Medical Fund http://honda-tech.com/zerothread/1828476 |
#16 |
That was just covered in another thread, but I always start Right rear, Left Rear, Right Front , Left Front. Never had a issue with that.
I don't know that it make a difference but I always close the bleeder before the pedal stops. I want the fluid moving not stagnet. |
#17 | |
I DonkeyPunch Hypocrites
Ride: 06 Mazda 5, 92 BMW 318is
do exactly as GSRCRX said
Now that Obama, a (half) Black man, is the President, I don't want to hear anymore about this so-called 'man' who's been holding your lazy ass back. Go get a damn job... |
#18 | |
i guess it depend on what car you have. my integra helms says left rear, right front, right rear, left front. my crx manual is differnt though, i dont know off hand though. but with the crx, ive never had a problem with farthest from master to closest either.
#19 |
For the CRX, the bleeding order is:
Left Front, Right Rear, Right Front, Left Rear (Straight from the Helms)
No tech questions through PM please! B16 CRX....you will be missed
#20 |
Thanks man, i have to buy a new alternator, i buy one for a 1990 integra correct? because i am obd0, then i will bleed the brakes again, also i bought the fuel rail and fpr off of a guy here on hondaswap. After that i should be good, only throwing that ground code, i think my ground in the fuse box is bad because i tried placing a ground in there for my gauges/tach and it didnt work, i had to relocate it, where does that ground go to in the engine harness?
And yesterday i got the tach wired and mounted where i want it, looks pretty nice!
#21 |
The Trisexual
Ride: 2007 Civic, 1995 Jeep Grand Cherokee
Instead of bleeding them like that. Try it the way I do it
1. Take a hose, put it on the bleeder screw. 2. Insert hose from bleeder screw and put it in a cup of brake fluid. -Make sure it's facing the ground. -Make sure it's submerged like an inch. 3. Open bleeder valve. 4. Pump brakes until you see no air in the tube or until you're satisfied. Move on to the next caliper and repeat. ---------------------------------------------------------- You only have to open and close the valve once, when it's submerged no air will be sucked back in, only brake fluid. When you do close it no air will be trapped either because BF will still be in the tube and any suction will just suck up some fluid. This has always worked for me and is a one person job. Or you can get a one-way speed bleeder valve and make it even easier. On the porsche, it took so long to get all the air bubbles out I just made a contraption with a vacuum...it actually worked well and took like 2 minutes a caliper if that.
DO NOT PM ME WITH TECH QUESTIONS!!! Current Rides 1995 Jeep Grand Cherokee =I love this truck 2007 Civic =Not sure what the future holds for this Previous 1992 Civic DX Hatch = 1994 B18B1 Turbo Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned, 253whp 1994 Civic VX Hatch, 1992 b18a1 swap 1993 Civic CX Hatch, 2000 B18b1 |
#23 | ||
right rear, left front, left rear, right front
#24 |
I did the bleeding the way gsrcrxsi said to and it still has not helped much, this is really pissing me off and i dont want to take this into a shop.
