booster pushrod adjustment
Old 07-16-2008, 02:23 AM   #1
Rep Power: 0 UrbanRacer is on a distinguished road
Default booster pushrod adjustment
i made the tool too break the star locknut loose and adjusted the pushrod out too free the pedal up. i am not adjusting the pedal hight.
too far out and the pedal has 0 freeplay like when the car is off. it does not more and barely barely stops. i slightly adjust it in and its like its too far in...
after a few hours of tinkering with it, the push rod looks like its pushin in..
ill take some quick vid of what im talking about.
you can see it sight back slightly and when i lightly tap it, it moves....is that enough play? when i pull the pedal, it sits "flush".....should it be there anyway?
UrbanRacer is offline   Reply With Quote
Forum Jump
valve adjustment, chipDA9 Integra 1 12-15-2007 02:20 AM
adjusting brake master cylinder pushrod? stmotorsports Wheels / Suspension / Tires / Brakes 7 08-05-2007 06:43 PM
Valve Adjustment Help HatchSpeeD General Tech and Maintenance 14 07-04-2005 01:31 AM
Timing adjustment.. Captinb16 General Tech and Maintenance 3 01-03-2004 09:43 PM
speedometer adjustment tylonalsnifnfool General Tech and Maintenance 5 12-23-2003 03:25 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
