brake fluid.....
Old 06-24-2003, 03:09 AM   #1
Rep Power: 14 sol2nr is off the scale
i don't know much at all about brake fluid.....
i have EBC slotted and dimpled rotors and Hawk HPS pads up front and stock brakes in the rear. I drive and brake aggressively and autocross sometimes. I am looking for the best brake fluid that is very daily driven worthy and will perform well at autocross events. i have a jdm b16a del sol.
What brake fluid do you recommend and why?
DOT3 or DOT4 or DOT5 and why....?
Genuine Honda or another company and why....?
thanks for any info.
-ROB
sol2nr is offline   Reply With Quote
Old 06-24-2003, 02:03 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
ATE blue
also known as smurff jiz
МОΛΏΝ ΛΑΒΈ
Old 06-24-2003, 03:00 PM   #3
B16
B16's Avatar
Originally posted by E_SolSi@Jun 24 2003, 10:08 AM
ATE blue
i also have used the motul RBF 600 (more pricey)
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 06-24-2003, 04:56 PM   #4
Chicks dig the box
90 accord's Avatar
Ride:  2006 Scion xB
Rep Power: 92 90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future90 accord has a brilliant future
Send a message via AIM to 90 accord
Originally posted by E_SolSi@Jun 24 2003, 01:08 PM
ATE blue
i bet you liked looking at that
i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i
http://www.hondashowoff.com/profile.php?id=3331 <-- my former SI
This is blue
90 accord is offline   Reply With Quote
Old 06-24-2003, 10:27 PM   #5
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Higher DOT ratings generally mean a "harder" fluid with better pedal feel and reaction, but it also means that they absorb water more quickly. You'll have to change higher DOT rated brake fluids more often than lower rated fluids. I run DOT 4 Motul 600 in my sedan.
Old 06-26-2003, 10:16 AM   #6
thanks for the info. so the only downside to getting DOT4 as opposed to DOT3 is that you'll have to change it a little more often and its more expensive...?
Old 06-26-2003, 10:20 AM   #7
is there anything special about genuine honda dot3 as opposed to say, STP Dot3? i mean, like is it specially formulated to not wear honda parts, sorta like the honda coolant doesn't contain silicates...?
thanks again for any info.
-rob
Old 06-26-2003, 12:28 PM   #8
Calesta's Avatar
Ride:  2003 S2000
Originally posted by sol2nr+Jun 26 2003, 09:21 AM--><div class='quotetop'>QUOTE(sol2nr @ Jun 26 2003, 09:21 AM)</div><div class='quotemain'> thanks for the info.* so the only downside to getting DOT4 as opposed to DOT3 is that you'll have to change it a little more often and its more expensive...? [/b]
Yeah, but not by much. I like to use DOT4.
<!--QuoteBegin-sol2nr
@Jun 26 2003, 09:25 AM
is there anything special about genuine honda dot3 as opposed to say, STP Dot3?* i mean, like is it specially formulated to not wear honda parts, sorta like the honda coolant doesn't contain silicates...?
-rob
[/quote]
I doubt it- it's a hydraulic fluid, not something that lubricates and protects or keeps moving parts in order- so use what you want.
Old 06-26-2003, 12:42 PM   #9
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Don't DOT4 and DOT5 fluids require you to run stainless steel lines? Or at least DOT5?
This space left intentionally blank.
Old 06-26-2003, 12:54 PM   #10
Calesta's Avatar
Ride:  2003 S2000
No, but it's nicer if you do. I run DOT4 in normal bulgy lines... although the Civic's lines have been steel braided for quite some time now.
brake fluid question BodyDroppedNikes Wheels / Suspension / Tires / Brakes 4 09-02-2004 01:38 AM
Brake Lights out HatchSpeeD General Tech and Maintenance 0 07-24-2004 08:24 PM
Type R brake swap using accord/prelude parts! Racecraft HYBRID -> EG-EK / DC 2 08-17-2003 06:37 AM
Brake problem CRX-YEM Wheels / Suspension / Tires / Brakes 4 07-18-2003 01:53 PM
Brake setup??? crxfreak Wheels / Suspension / Tires / Brakes 0 07-01-2003 08:22 PM
