#1 | |
...PENDEJO....
Ride: bagged Ford Ranger Splash
i need to add brake fluid to my car (i got an ABS system on my 1990 Integra GS)and was wondering if i am going to have to bleed the lines after filling the ABS brake fluid reservoir. thanks all!!
***Please leave this section blank. For office use only.*** -BrianE. 1995 Ford Ranger Splash 2009 Ford Focus http://midwestminis.forumotion.com/forum.htm Quote:
Ride: 95 Honda Civic EX
not unless you dont feel that much pressure in your pedal. You can add to the resivoir without bleeding.
http://www.myspace.com/allbottledup email allbottledup@hotmail.com or Russelchiacchia@comcast.net |
Ride: 1995 Civic EX coupe
if the level in the reservoir is just low, you'll be fine. if there's no fluid in the reservoir, you probably have air in the lines and will need to bleed. You might even need to bench bleed the master cylinder.
#5 |
B happy
Ride: dohc 95 egg
No, if your just adding to raise a low level. Like said before if it has dipped to teh point of being empty than yes.
