| | LinkBack | Thread Tools |
| | #1 |
| Super Moderator Join Date: Sep 2002 Location: Wallingford, CT Age: 32
iTrader: 0 / 0% Ride: 91 CRX
Rep Power: 87 | Well this morning drivin to work like any other day. well I get off the highway start to slow down no problem, then coast a little as it's a long exit ramp uphill, hit the brakes gain except this time the peddle almost goes to the floor still stopping me but scarey. continue on my normal route keeping at a much slower speed than usual, put the brakes on and the peddle goes much closer to the floor than normal and doesn't feel like it has as much force (the pressure you feel as you apply the brakes). I took a peek under the hook looked at the resivoir and it's not at the MAX line but just under so I doubt that the problem has to do with low brake fluid. only things crossing my mind, rear drum brakes (that little thing that actuates the brake is shot and pissing fluid in the drum) , a brake line broke, or the master cylinder is shot, front caliper is fucked up , I guess hell it could be anything. Anyone have any ideas what might be wrong ???
__________________ Dennis Please don't PM/Email/IM me for technical support. Make a Post!!! 91 CRX DX, 03 Civic EX "There are 10 kinds of people in the world: those who get binary and those who don't." "Of all my imaginary friends I don't think there was one I didn't end up having to kill" |
| | #2 |
| RETIRED | you actually used your brakes at autoX and now they are dead :P but seriously, if you had a leak in the line, your brakes would be out. the pedal would go to the floor, as all the pressure would push it out, and the pedal woudl drop to the floor before the fluid could make enough pressure to slow yo down. as for the drums, the "little thing that actuates" the brakes is actually a "spring". again, if fluid was leaking out, see above. if a front caliper was shot, you'd have un-even braking, but the pedal wouldn't go to the floor. my guess is the master cyl. check the vacuum line on the booster.. see if that is ok (it should be from the sounds of this) don't quote me on the master though... im no tech... but thats what it sounds like. before you leave work today, turn the car on and pump the brakes like 5 or 6 times really fast, really hard, and as far down as you can each time. if by the 2nd or 3rd pump the pedal is not getting hard as fuck and stopping up top, it's probably the master cyl. |
| | #3 |
| Super Moderator Join Date: Sep 2002 Location: Houghton/Livonia Michigan Age: 23
iTrader: 0 / 0% Ride: 93 del Sol Gas sipper
Rep Power: 102 | No b, here is how to test if the master cylinder is bad, when the car is OFF, pump the brakes, if by the 2nd to 3rd time it does not get hard, then it is your mastercylinder. Now turn on the car with you pressing the brake pedal, if it moves down more then an inch-inch and a half, your booster is probally bad. |
| | #4 | |
Rep Power: 87 | yeah, I'm betting on the master cylinder. because the feel of the pedal has been inconsistant for a little while. Not like today but sometimes it's firmer than other time. and today was just the straw that broke the camels back. Quote:
| Brake Lights out | HatchSpeeD | General Tech and Maintenance | 0 | 07-24-2004 07:24 PM |
| Electrical Problem With My 1986 CRX Si | The_MATRIX | General Tech and Maintenance | 0 | 06-17-2004 05:08 PM |
| please help with brake problem | hotcivic | Wheels / Suspension / Tires / Brakes | 0 | 06-13-2004 11:51 PM |
| Brake Light Electrical Problem | Psyco609 | ECU's, Electronics, and Tuning | 1 | 06-09-2004 12:17 AM |
| brake problem? | honcrx91si | Wheels / Suspension / Tires / Brakes | 1 | 04-18-2004 12:53 PM |
