brake system volume?
Old 06-15-2005, 01:47 AM   #1
seanjuan's Avatar
Ride:  See sig.
Rep Power: 23 seanjuan is off the scale
just wondering if anyone knows how much brake fluid a 5thgen civic/3g teg holds?
I was an idiot and listened to the guy at the parts department (Honda) when he said that I would only need one bottle of fluid... pretty sure I'm going to need more now as I'm not done bleeding yet and I'm out of fluid
I completely drained my brakes, calipers, lines and all
also, does anyone have any good tips on bleeding brakes... is it just a real pain in the ass when you have an empty system... seems like it's taking too much time and I'm not getting much for results?
do you have to turn the car on ever to help build pressure in the system?
sorry, I haven't ever worked on brakes before so I'm not to privy on all the new s##t
thanks
Sean
'92 Civic LX - for auto-x
'03 Suzuki SV650 - for speed
'02 VW GTI 337 - for fun
seanjuan is offline   Reply With Quote
Old 06-15-2005, 09:29 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
1 bottle should be enough. depends on the size of the bottle though i guess.
its really a two person job. you can't physically hold down the pedal and release the system pressure by yourself.
no need to turn the car on.
pump pump pump... make sure master is topped off, bleed
RRear
LR
RFront
LF
furtherst away from master to closest.
when the RR starts spitting out pure fluid, no air bubbles, shes done. close it up, and go to the next one.
Old 06-15-2005, 11:07 AM   #3
seanjuan's Avatar
Ride:  See sig.
I think it is just a pint bottle.... but it has to fill the pistons as well as the lines because I totally drained them
I have been using a vacuum kit that I bought but also had someone helping me out as well...
thanks though
Old 06-15-2005, 01:45 PM   #4
Rep Power: 10 abdelsol is off the scale
Why did you drain the system?
Master cylinder too?
Pint will not be enough get a quart. If the system set open by more and flush it..... Fluid it cheap...... not stopping priceless....
abdelsol is offline   Reply With Quote
Old 06-15-2005, 02:01 PM   #5
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
I used over a quart when I did mine, no wya a pint is going to be enough if you emptied them.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 06-15-2005, 10:41 PM   #6
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
The last time I did a full system flush, it only took me a pint- and that was with the larger 15/16 master cylinder too.
Old 06-16-2005, 12:05 AM   #7
RETIRED
werd, i've never used more than that...
and i have the larger GSR master resivoir on my car now.
Old 06-16-2005, 02:42 AM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Likw whoa, I had more than a pint in the bled bottle.
95 CX|B16A2
Old 06-16-2005, 10:09 AM   #9
RETIRED
if you're bleeding more than a pint, you're doing something wrong. a quick "Pssspft" and re-tighten is all you need. you don't have to sit there and let it drip out. a table spoon to about 1/4 cup per corner of spent bled fluid is about average i'd say.
Old 06-16-2005, 10:31 AM   #10
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Everytime I have bled brakes after draining or nearly draining the system, it takes more than a couple quick hits at each corner.
95 CX|B16A2
Old 06-16-2005, 10:51 AM   #11
RETIRED
sure- the first corner takes a while... but theres no need to let perfectly good fluid out. you're trying to get rid of the air in the lines-- not the fluid in the lines.
Old 06-16-2005, 11:36 AM   #12
seanjuan's Avatar
Ride:  See sig.
yeah, I think I have been letting too much fluid out... especially at the first corner
I drained the whole system because
A. it was original old fluid
B. I replaced all the calipers/drums with the brakes from a 98 gsr
c. I put on a 7/8 MC
d. I replaced the hardline going to the front right
anyway, a buddy of mine that works at honda gave me another pint for free so that should be enough to finish even if I over do it a little
I kind of was doing it to flush the old dirty stuff out of the lines and calipers as well
Old 06-16-2005, 12:37 PM   #13
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by pissedoffsol@Jun 15 2005, 02:29 PM
RRear
LR
RFront
LF
Actually, it's R Rear, F left, R left, F right
95 CX|B16A2
Old 06-16-2005, 12:48 PM   #14
seanjuan's Avatar
Ride:  See sig.
Originally posted by 92b16vx+Jun 16 2005, 11:37 AM--><div class='quotetop'>QUOTE(92b16vx @ Jun 16 2005, 11:37 AM)</div><div class='quotemain'><!--QuoteBegin-pissedoffsol@Jun 15 2005, 02:29 PM
RRear
LR
RFront
LF
when the RR starts spitting out pure fluid, no air bubbles, shes done.* close it up, and go to the next one.
[/b][/quote]
yep, that is what Helms says
Old 06-17-2005, 12:18 AM   #15
RETIRED
odd... my del sol one says the way i have.
technically, you're supposed to start from the furthest path and work your way to the shortest path.
i dunno.
Old 06-17-2005, 12:26 AM   #16
...Hi...
HatchSpeeD's Avatar
Rep Power: 26 HatchSpeeD is an unknown quantity at this point
Send a message via AIM to HatchSpeeD
i dunno.
Thats what I heard too. Damn these conflicting methods right before i'm doin a brake swap.
When you said you drained the whole system, did you let the MC go empty? If so, is that bad? I heard not to let the MC go empty when you bleed brakes because something about damaging the seals in the mc. Is that true because at the sametime, how else are you suppose to completely flush the old fluid if you wanted to do so unless you just kept pouring more and more fluid and bleeding the crap out of it.
HatchSpeeD is offline   Reply With Quote
Old 06-17-2005, 12:34 AM   #17
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
i just follow what the helms says, and its always worked for me
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 06-17-2005, 05:45 AM   #18
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
i dunno.
What year DelSol Helms do you have? I got that from the 95 DelSol and the 94 Civic.
95 CX|B16A2
Old 06-17-2005, 09:33 AM   #19
RETIRED
actually, my helms is for a 94 integra
Old 06-17-2005, 10:35 AM   #20
seanjuan's Avatar
Ride:  See sig.
brakes are bled and the car stops when the pedal goes down
pedal isn't very stiff but it feels ok
I might rebleed a little to see if there are any tiny little spare bubbles hanging on in there
only thing is that the hawk pads I put on the back came with a backing plate on them that doesn't work with the caliper.... the caliper only contacts about half of the backing plate... and therefore the pad is only using the outside half of the rotor
I'm thinking that I will pull the pad out and remove the hawk backing plate and put the honda one on from the old pads
Old 06-17-2005, 03:15 PM   #21
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Did you use all teh shims?
95 CX|B16A2
Old 06-17-2005, 05:47 PM   #22
Calesta's Avatar
Ride:  2003 S2000
Originally posted by 92b16vx+Jun 16 2005, 12:42 AM--><div class='quotetop'>QUOTE(92b16vx @ Jun 16 2005, 12:42 AM)</div><div class='quotemain'>Likw whoa, I had more than a pint in the bled bottle.
[/b]
I have too, but only on a Civic with a leaky master cylinder.
@Jun 16 2005, 08:09 AM
[/quote]
I was talking about a full system flush- I was watching the color of the fluid change so I knew when all the old stuff was out. It wasn't just a bleed job.
Old 06-17-2005, 06:16 PM   #23
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by Calesta+Jun 17 2005, 10:47 PM--><div class='quotetop'>QUOTE(Calesta @ Jun 17 2005, 10:47 PM)</div><div class='quotemain'><!--QuoteBegin-92b16vx@Jun 16 2005, 12:42 AM
[/b][/quote]
That jives, my prop valve had a bad fitting and leaked slowly, so that's probably why
95 CX|B16A2
Old 06-18-2005, 01:02 AM   #24
seanjuan's Avatar
Ride:  See sig.
I didn't reuse the shims on the back because the shims that are rivetted to the hawk pads don't jive with the honda shims
so I think I'm going to break off the Hawk shims and put the honda ones on there so that the caliper makes proper contact with the pad
Old 06-19-2005, 01:01 AM   #25
Ride:  1995 Civic EX coupe
Rep Power: 14 bcman is an unknown quantity at this point
I also vote for the RR, LF, RF, LR method. Honda splits brake fluid into two lines, one to RR & LF, and one to RF and LR. so do one diagonal pair first, then the other.
bcman is offline   Reply With Quote
