Facebook Twitter
Brake Upgrade 4 My Eg Hatch
This is a discussion on Brake Upgrade 4 My Eg Hatch in the Wheels / Suspension / Tires / Brakes forum
Hi, I have a 94 hb cx and yea, the brakes suck. I wanted some bigger rotors in the front with better calipers and shite. Is the 94+ tegs good for the front brake swap? What will I need exactly for the swap, or can ...
Old 05-20-2003, 09:42 PM   #1
HatchSpeeD's Avatar
Is the 94+ tegs good for the front brake swap? What will I need exactly for the swap, or can i just simply take off the rotors and calipers and such and mount it right on.
Any other choices?
What about the rear drum 2 disc swap? Again, what should I use or what do I need? I'm looking to try and get all the parts from a junkie. (no not a drug addict :P ) Thx
HatchSpeeD is offline   Reply With Quote
Old 05-20-2003, 10:02 PM   #2
94+ integra, 99 si, del sol si, um...thats all i can think of.
you can swap those parts onto your eg. trailing arm, rotor, etc.
eyesonlybob is offline   Reply With Quote
Old 05-20-2003, 11:23 PM   #3
HatchSpeeD's Avatar
What does the trailing arm look like and what purpose does it serve?
Thx
Old 05-21-2003, 10:09 PM   #4
Those huge black arms that the brakes and the shocks are attached too are the trailing arms, you can't put oem rear discs on without getting the whole trailing arm assembly. If you are upgrading your front brakes with oem brakes you need the full front hub assembly off the donor car.
Baker is offline   Reply With Quote
Old 05-22-2003, 05:09 AM   #5
HatchSpeeD's Avatar
Thx for picture man.
Old 05-22-2003, 05:11 AM   #6
HatchSpeeD's Avatar
oh yea one more thing, if i do the teg/si rear disc swap...which parking brake cable do i use?
I also heard you need to change your master cylinder and all that junk.
Old 06-03-2003, 09:26 PM   #7
if your car doesnt have ABS and the donor car does that make any difference??
highperboi is offline   Reply With Quote
OEM brake upgrade 94 ex w/out ABS sleepercivic Wheels / Suspension / Tires / Brakes 10 07-09-2004 02:51 PM
Brake Upgrade Question NoJokE Wheels / Suspension / Tires / Brakes 8 04-25-2004 04:07 AM
Big Brake Upgrade 95hatchcx Wheels / Suspension / Tires / Brakes 3 03-17-2004 04:57 AM
Anyone here? 2000Si Members' Lounge 14 12-09-2003 10:55 AM
Best brake upgrade? brc80 Wheels / Suspension / Tires / Brakes 2 10-07-2003 09:51 AM
© 2001-2013 HondaSwap.com
