I have a '93 Ex, with no ABS and back drums. I want to upgrade the back to discs, but i am also planning big power and want to run a 13" slick. I know if i upgrade the back and not the front there will be uneven brake distribution.
Will a GSR brake conversion up front and back allow me to still run a 13" Slick? Or should i just get some new rotors, Hawk HPS Pads, SS Braided lines on my stock ish and call it a day? __________________
T3T67 ![]() <a href=\"http://www.hondaswap.com/forums/index.php?showtopic=69573\" target=\"_blank\">Buy my MSD 6AL, Carsound Cat, VTEC Distributor!</a> <a href=\"http://ipods.freepay.com/?r=11169222\" target=\"_blank\">Sign up for a Free Ipod!</a> |
B happy
Ride: dohc 95 egg
Brake distribution will be determined by the proportioning valve.
Some models even though they have drums in the back, the prop valve may not need to be changed. You need to look at the number on the side ones that have the same two numbers, 40/40, 30/30 are fine, if it says something like 40/30, 30/20, you might want to change it. __________________
#4 | |
#5 |
I just checked and the proportioning valve says 3030 on it.
#8 |
Hmmm, Will i be able to upgrade the back to discs and still keep my stock fronts without any ill effects??
#9 |
B happy
Ride: dohc 95 egg
Yes, they should be fine. If I remember correctly, the EX has the larger drum, with a smallish front, so the balance is the same as with a small rear disc such as the Del Sol vtec, or GSR. Now if you go slap the Prelude, ITR or some other larger rear disc on there, you could throw it out wack.
| brake fluid question | BodyDroppedNikes | Wheels / Suspension / Tires / Brakes | 4 | 09-02-2004 01:38 AM |
| OEM brake upgrade 94 ex w/out ABS | sleepercivic | Wheels / Suspension / Tires / Brakes | 10 | 07-09-2004 03:51 PM |
| Best brake upgrade? | brc80 | Wheels / Suspension / Tires / Brakes | 2 | 10-07-2003 10:51 AM |
| OEM Brake Upgrade | JrSiRb16A | Wheels / Suspension / Tires / Brakes | 2 | 07-26-2003 11:02 PM |
| civic to GSR brake upgrade (front & rear) | slowasscx | Wheels / Suspension / Tires / Brakes | 11 | 01-08-2003 04:18 PM |
