Camber after lowering, and informative.
Old 07-02-2005, 01:30 PM   #1
!!YTINASNI
phyregod's Avatar
Ride:  97 teggy, 98 jeep GC 4x4, 07 CBR 1000rr
Rep Power: 163 phyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
I see alot of camber questions about lowering, and alot of false info, So I am posting my information to clear up some rumors about camber, and camber kits.
I dropped my CRX 1.8/2.0 inches with neuspeed springs.. with a b18a sitting in the bay, and starting with good camber, here are the readings.
specified is factory recommended
Actual is what my car was reading after the drop and swap.
CAMBER READINGS: Taken by a professional alignment shop. Of course, all cars are not the same, and yours might be different, but this just shows what happens when you lower your car, and what you can expect in therms of camber adjustment.
Front Left
Specified: -1.0 to 1.0 degrees
Acutal: -2.2 degrees
Front Right
Actual: -2.0
Rear Left
Specified: -1.4 to .6
Actual: .9
Rear Right
Actual: .9
So, the front has too much camber and will need to be corrected with a camber kit. The rear is just fine.
I must disagree with the people who say that a 2 inch drop does not require a camber kit.
aleaf.CRX: I don't think I've ever had the steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane one day and attack someone
Old 07-02-2005, 02:01 PM   #2
Rep Power: 17 CiViC_SOHC is off the scale
Send a message via AIM to CiViC_SOHC
ditto 2 inch drop or more DOES need a camber kit ive said that ever since I been on here lol....my car is dropped like 3 inches and my camber is FUCKED just put my camber kit on and waiting to get it aligned!!
1992 EG8 Civic Sedan / '98 D16Y7 swapping a D16Z6...TURBO!
Support the local Performance shop. <a href=\"http://aeiperformance.com/\" target=\"_blank\">AEI performance</a>
CiViC_SOHC is offline   Reply With Quote
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
