Facebook Twitter
Camber kit opinions
This is a discussion on Camber kit opinions in the Wheels / Suspension / Tires / Brakes forum
im on a tight budget so does anyone have experience with camber kits such as ingalls? ebay control arms? i know everyone is gonna say get skunk2 and what not but i cant afford it right now so please, opinions on the aforementioned parts please...
Old 11-14-2009, 01:57 AM   #1
Default Camber kit opinions
REPTAR is offline   Reply With Quote
Old 11-14-2009, 10:03 AM   #2
Calesta's Avatar
Look for a used Progress kit that relocates the upper mounts. Cheap, effective and durable. Ingalls have a lot of imitators on eBay that break, Skunk2 isn't cheap.
Old 11-14-2009, 06:26 PM   #3
Slow&Delirious's Avatar
what kind of car have you lowered, in some cases washers will fix camber issues, ex. older integras in the rear
Slow&Delirious is offline   Reply With Quote
Old 11-15-2009, 01:15 PM   #4
well i went and got an alignment yesterday at a local speed shop and they dialed out most of the negative camber so i guess this whole post has been a mute point!
Old 11-15-2009, 02:56 PM   #5
phyregod's Avatar
Camber on a stock honda is not adjustable! If they adjusted it, I would take it straight to another shop and make sure they didn't fuck something up. Unless honda started putting adjustable setups in their cars recently..
Old 11-15-2009, 03:49 PM   #6
to a certin point its not adjustable, but in my case i only had an inch and a half drop and when we aligned it at school, we got the needle just inside the green. but any more than that and we couldnt have corrected it
Old 11-15-2009, 04:12 PM   #7
K2e2vin's Avatar
I honestly don't see how you'd adjust the camber, at least up front(rears can be shimmed out).
I'd say the Hardrace upper A-arm is probably the best you can get besides the A-Sports one which probably costs 3x more. The Hardrace unit uses bigger bolts than the Skunk2 which means much less chance of it slipping. Matter of fact, I've yet to hear the Hardrace slipping while a couple of guys RR/AutoX guys on HT have had the Skunk2 slipping.
Old 11-15-2009, 04:19 PM   #8
i couldnt tell you how we did it on my del sol, but we adjusted bolts untill every gauge was barely in the green.
Old 11-15-2009, 04:30 PM   #9
K2e2vin's Avatar
Adjusted the bolts(re-torquing or something?), or just unbolted them and reinstalled them or loosened them and torquing them down("resetting" the suspension bushing so they're not binding)?
Old 11-27-2009, 12:08 PM   #10
Is a camber kit necessary when you lower a car?
I have a 2000 teg lowered on agx's and sportlines. Shoud I pick a camber kit up?
whyamionahondaforum is offline   Reply With Quote
Old 11-27-2009, 07:37 PM   #11
BrutalB83's Avatar
For the Sportlines it would probably be a good idea. A good general rule of thumb is that anything lowered past 1.5 inches will probably need a camber kit...
Old 11-30-2009, 06:28 PM   #12
awptickes's Avatar
My car needed camber adjustment after I lowered it 20mm.
If you change the suspension geometry AT ALL, you need to fix it afterwards. Besides, an extra degree of negative camber will help handling more than you'd think.
awptickes is offline   Reply With Quote
Old 12-01-2009, 12:15 PM   #13
BrutalB83's Avatar
Whatever you decide to do, make sure to get the alignment checked when you're done installing new suspension components...
6th or 7th Gen--Your Opinions tbealmear Accord 10 12-17-2006 09:25 PM
Want some opinions... Cliff Forced Induction 3 12-04-2004 11:27 PM
Need Opinions BlackFrog Wheels / Suspension / Tires / Brakes 6 11-13-2004 07:26 PM
need opinions 90 accord Engine Building 20 04-19-2004 07:05 PM
Just getting opinions Drock42 Members' Lounge 13 09-30-2003 12:09 PM
© 2001-2013 HondaSwap.com
