Installed Buddy Club N+ Spec Dampers and the lower mounting point onto the LCA, (the fork) has two aluminum shims for the EK, took those out so the EG bolt would fit, but now the original EG bolt is too small......any suggestions?
It is clicking when I shift through the gears because of the torque on the suspension. It's tight, torqued to spec, but I know that clicking is coming from it. Should I just buy new bolts in the right diameter from the hardware store? What would you guys do? ![]() __________________
Thou shalt always seek the redline Do. Or do not. There is no try. "Doesn't matter how you find the pot of gold; All that matters is that you beat the leprechauns." Last edited by EGDriver93; 09-27-2009 at 04:17 AM. |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
def. get the right bolts..you dont want that snapping because it will mess everything up
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
Yeah.....you'd think that once you take the shims out that the original EG bolt would fit perfect, NOPE!! its about 1/4" too small. Thanks for the input guys!!
Thou shalt always seek the redline Do. Or do not. There is no try. "Doesn't matter how you find the pot of gold; All that matters is that you beat the leprechauns." |
#5 | |
Ride: gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Get that fixed right away. The looseness is causing fretting (surface to surface wear that develops cracks in a metal). You also need to replace it with a high grade bolt. I've been bitten in the ass before when I was too lazy to hunt down a grade 10 fastener. Basically the bolt warped and when I tried to take it apart it was damn near impossible. I'm lucky it didn't snap while driving.
93' dx hatch jdm b18c - jrsc 8psi s300 440cc RC's |
| 88-91 crx lower control arm coilover&rear camber kits | RSS-Bot | Auctions | 0 | 01-06-2009 06:17 PM |
| 88-91 civic lower control arm coilover&rear camber kits | RSS-Bot | Auctions | 0 | 01-01-2009 07:50 PM |
| 88-91 crx lower control arm coilover&rear camber kits | RSS-Bot | Auctions | 0 | 01-01-2009 07:50 PM |
| 94-01 integra lower control arm coilover & rear camber | RSS-Bot | Auctions | 0 | 12-23-2008 07:36 PM |
| 93-97 Del Sol LOWER CONTROL ARM COILOVER&REAR CAMBER 95 | RSS-Bot | Auctions | 0 | 12-23-2008 07:36 PM |
