| | LinkBack | Thread Tools |
| | #3 |
| Senior Member | You need to disassemble the whole strut. Remove the spring and then put the springs on. Then bolt everything back together and in the car! Just make sure you cut your bump stops in half! |
| | #4 | |
| Senior Member | Quote:
| | #5 |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | If you're lowered, you want to cut the bump stops so you regain some suspension travel. Civic have tons of space inside the wheel wells, and it's a shame to be bouncing off your bump stops when you still have space to compress... |
| | #7 |
| Member | i meant the cup like dish that the bottom of the spring rest on. take a look at this and tell me if this guy is correct or full of sh**. http://freepages.autos.rootsweb.com/~jaime...ta/gc_coilover/ |
| | #8 |
Rep Power: 392 | The perch? Sometimes you have to move it, sometimes you don't... it depends on the installation and what parts are provided. You'll typically need to transfer it to the new shock setup though. |
| | #12 |
| Senior Member | I wouldn't cut them anything less than 1/4th the original! If it got any thinner than this and your shock bottomed out too hard! CRIZZZZACK! then you will crack and blow ya shock! |
| B Series Cam Guide | JDMilan | Reference Materials | 35 | 04-13-2007 08:26 PM |
| Stock Springs on Illuminas? | Citizen_Insane | Wheels / Suspension / Tires / Brakes | 7 | 06-16-2004 02:41 PM |
| Education | FirstAccord | Wheels / Suspension / Tires / Brakes | 13 | 06-16-2003 04:03 PM |
| Wich Lowering Springs | ovcrash | Wheels / Suspension / Tires / Brakes | 19 | 02-15-2003 10:55 PM |
| salvage yard springs | turntune | Wheels / Suspension / Tires / Brakes | 5 | 10-14-2002 08:13 PM |
