Banned
ok...have an 89 crx dx. tire pressures in owners manual say 32/32 for the dx. car came with 175/70r13's
now i have the same as the si's wheel and tire package (185/60r14's). owners manual says for si's, should be 28front/28rear. which pressures should i go by? the guys who installed them at america's tire made them 32/32 but is that correct? |
Ride: 93 del Sol Gas sipper
My stock wheels on my sol are 14's and i am almost positive that they recomend 31 psi.
Collin Material Science and Engineering Michigan Technological University |
Admin with a big stick
Ride: 2003 S2000
Try out different pressures until you find the one that you like best... optimal pressures vary from tire to tire. With my Dunlop SP8000s, I ran 33psi cold- with the S-03s I run 36psi cold. Try out different combinations front and rear to get the best combination of turn-in, ride quality, mileage, cornering and straight line traction, etc that you want.
I have an CRX Si, when i dont have my Mags on with proxxie T1's. i run the stock 185-60-14's at 30 Psi. SO ull b safe with 32.
Sleepers Are the Only way to Go. 1990 CRX Si B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears. 1/4 = 14.73 60' = 2.48 trap = 95.03mph Soon to get: Header, Slicks Future 13 second all motor LS! |
| Fuel Pressure question | TeamUrbanChaos | ECU's, Electronics, and Tuning | 3 | 05-08-2006 05:44 PM |
| Greddy Oil pressure gauge question | 94CivicSlow | General Tech and Maintenance | 2 | 06-19-2005 07:26 PM |
| tire pressure question | 92CHB | Wheels / Suspension / Tires / Brakes | 8 | 10-07-2004 12:17 AM |
| Basic Tire Info | pissedoffsol | General Tech Articles | 0 | 01-12-2004 01:44 AM |
| Vtec, VAFC, and oil pressure question | 92b16vx | ECU's, Electronics, and Tuning | 1 | 10-24-2003 04:39 AM |
