del sol sway bar
Old 03-27-2008, 11:10 PM   #1
Big WIll
Wilshire's Avatar
Ride:  1997 del sol v-tec
Rep Power: 6 Wilshire is on a distinguished road
Default del sol sway bar
what size is the front sway bar on the 97 del sol vtec??? im thinking of upgrading to a type r unit, but the stock one on the sol is pretty big already...
Wilshire is offline   Reply With Quote
Old 03-28-2008, 12:32 AM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
why upgrade the front? it will only increase understeer (plowing)
do you already have a large rear sway bar that is causing your car to be too tail hapy??
МОΛΏΝ ΛΑΒΈ
Old 03-28-2008, 12:58 PM   #3
Big WIll
Wilshire's Avatar
no i do not have a larger aftermarket rear sway bar. My car already gets loose a bit in hard cornering, alot of the time. So your saying that a larger rear sway bar would just make this worse???
thanks
Old 03-31-2008, 11:31 PM   #4
Rep Power: 43 vtecsir1 will become famous soon enough
so many things can cause that! list your setup then we can chat
vtecsir1 is offline   Reply With Quote
Old 04-01-2008, 05:26 PM   #5
Big WIll
Wilshire's Avatar
as of now i have billstein struts (the two left are leaking) i bottom out on almost every semi hard right turn!! with eibach springs and a dc sports rear strut bar.
Soon to be installed --- in my room ive got some Tanabe Sustec pro s-s full coilovers, Skunk 2 rear tie bar, Blox rear LCA's and an Energy Suspension Hyperflex bushing kit.
So my questions are; will the itr rear sway bar help with my soon to be set up??? and what front strut bar do you recommend???
Old 04-02-2008, 12:30 AM   #6
well after all of those mods go on then see if you have the same issue, bad shocks certainly dont help your situation.
i have a 23mm jdm itr rear bar and a 21mm suspension techniques front bar but i like having oversteer. with a larger front bar than rear bar you pretty much will be "plowing" understeering.
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
4dr sway bar install hondadriver Wheels / Suspension / Tires / Brakes 2 08-19-2004 12:21 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
Education FirstAccord Wheels / Suspension / Tires / Brakes 13 06-16-2003 05:03 PM
Sway Bars In Hatch CivOnDubs Wheels / Suspension / Tires / Brakes 1 02-24-2003 01:34 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
