91 CRX HF. I just changed the brakes a few days ago, and im dead sure that i replaced everything just right. However, the pads were almost completely gone. After I replaced it with new pads and rotors, I drove it to work, on the way to work the right side started to shudder and felt like ABS was kicking in (of course i dont have ABS, just felt like ABS does) the noise and shudder would stop if I depressed the brakes and would return as soon as I let up. And there was a horrible smell burned brakes when I tried to check it out on the side of the road. Ive got some ideas but I would like to see your thoughts, thanks.
91 CRX HF-ZC motor and tranny swapped -This is what the HF should have been, just a low redline..... "My Car should Qualify as an ULEV. An Ultra Low Expectations Vehicle" -no more that motor is outta here! |
is the easiest solution just to replace the caliper? I would assume so.
#5 | |
!!YTINASNI
And replace or have the rotor surfaced.. Its junk at the moment.
#6 |
I forgot to mention that i had rotated the tires as well, a friend of mine suggested that he thought it was more likely the wheel than it was the brakes. This is an experienced mechanic, so this isn't just a guess. Ill be switching out the tires today to see if it makes a difference.
#7 |
my front motor mount is also busted (actually a tranny mount i think), could this have something to do with it? It seems to be making a little poping noise everytime I push the clutch in while the car is moving that is not the same as the mount hitting the engine bay (
I know what sound that is). Something that it did not do before I changed the brakes.__________________
| brakes | civiclxb16 | Wheels / Suspension / Tires / Brakes | 6 | 07-02-2005 12:12 PM |
| whats going on with my brakes | GSRCRXsi | Wheels / Suspension / Tires / Brakes | 5 | 06-11-2005 12:00 AM |
| Civic Sir Brakes | IceBolt | Wheels / Suspension / Tires / Brakes | 1 | 04-19-2003 06:50 PM |
| Hf Brakes? | stud4u2c17 | General Tech and Maintenance | 1 | 03-04-2003 02:02 PM |
| Nsx Brakes On Ef Feels Spongie | Ef_squadron | Wheels / Suspension / Tires / Brakes | 2 | 02-28-2003 12:16 AM |
