What do you guys recommend for increasing my traction ability when i launch? Its completly stock suspension with 195/50/15 Cooper cobra's . Once the tires go im going to upgrade to 205 Falkens. But i was looking for advice about the suspension
thanks |
Ride: 01 is300, 05 s2000, 03 rx300
get some quality coilovers.
get some jimfab bars or z10 rods get some s-03 pole positions or some other sweet tires. coilovers... tein are excellent... JIC, buddyclub.. or you can go cheaper route ground controls/ kyb or koni whats your budget |
Member of the 20 nut club
get the ground control drag setup
get some adjustable struts you want to lift the rear (to put more weight on the front tires) and you want to have the rears stiff as fuck (to reduce weight transfering off the front to the rear) |
#6 |
FüK-VTEC
pull forward out of the burnout box.
that's always a plus. ![]() seriously though, get hella stiff shocks on the back, and get a set of coilovers and raise the back up a bit, and don't get Kumho 711's. |
#7 |
RETIRED
falkens are NOT drag tires. you'll bake them up. they are autocross tires, and are great for 2nd - 4th gear hard driving, but will net you a 2.5 60' most likely still.
if you want drag tires, get some BFG drag raidals |
#10 |
Ride: 93 del Sol Gas sipper
a cheap thing to do is to buy some mount inserts. This will help make the engine stay more stationary so you put more power down, and less wheel hop.
| Q's about traction bars/systems | hybrid89 | Wheels / Suspension / Tires / Brakes | 6 | 07-30-2004 08:06 PM |
| Swapping B16A2 into '92 EG - Needs advice! Help! | asin | HYBRID -> EG-EK / DC | 7 | 05-21-2004 03:03 PM |
| Traction Bars | dragoon118 | Wheels / Suspension / Tires / Brakes | 24 | 08-13-2003 08:09 AM |
| Z10 Traction Bar? | ek9r | Wheels / Suspension / Tires / Brakes | 32 | 04-19-2003 09:01 PM |
| Z10 Traction Bars | dvs_prelude | Engine Building | 6 | 03-28-2003 08:50 AM |
