hrm.... vote on this
View Poll Results: what to do.....
1- USDM ITR 5-lug conversion. $2000-2500 minus my stuff/wheels/tires/ = $1000 ish 5 20.00%
2- replace the del sol si rear caliper $200-350 5 20.00%
3- usdm 94+ gsr brake conversion. $200-650 11 44.00%
4- Rear Disc Brake swap from a DelSol Vtec 4 16.00%
Voters: 25. You may not vote on this poll
Old 08-05-2003, 05:50 PM   #1
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
well, i got a fucked up rear caliper. its like frozen or something. still driveable, its just always on... slowing me down, and most importantly, eating a set of pads/rotors in a month.
i gave up on maintaining it... as i have a set of brembos/ebc greens to go on when the swap goes...
well, that doesn't solve my caliper problem....
here are my options i'm weighing-
1-USDM ITR 5-lug conversion.
usdm cuz i jsut bought stage2 axles, and don't want to run a weak ass accord outer joint to the jdm itr hub.
pros-
bad ass stopping power
bad ass looks
cons-
probably will need new pads and rotors on top of the initil cost
will ned 5-lug wheels
did i mention expensive?
pros-
easy to do
can keep same wheels
cons-
availbility of just a caliper for a del sol si rear (no other car uses it, not even the vtec model del sol) is limited at best, and thus will come with a cost from the honda dealer
pros-
cheap. i found a set of 4 for 200 bucks with Spindles w/ Brake Calipers, Rotors and Hubs
can use same axels
better braking than stock del sol si brakes
cons-
who knows the brakes condition. so, figure add another 450+ on brake parts to get some new rotors and pads on that biotch.
4- Rear Disc Brake swap for a civic, from a DelSol Vtec
pros-
about 250 bucks
better availbility of rear rotor sizes
cons-
can't use the brake stuff i have on the rear cuz the rotors are a different size.
I've spent so god damn much on this car, its like whats another grand....
5- fast brakes upgrade
pros- bad ass brakes.
cons- $$$$$$$$$$$$$$$$$$$$$$
but at the same time, i don't really want to put another dime into it.
if you were in my situation, what would you do?
Old 08-05-2003, 06:00 PM   #2
hcivic.com is on a distinguished road
man rebuild that caliper
cost 45 bucks
hcivic.com is offline   Reply With Quote
Old 08-05-2003, 06:05 PM   #3
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
lsvtec is on a distinguished road
Fastbrakes if and only if you have the 11" front kit as well. Yeah it costs alot, but it stops better than the ITR conversion, it looks cooler than the ITR conversion. Did I mention that it stops better...
I would go the same route again if I had the choice.
Fastbrakes
lsvtec is offline   Reply With Quote
Old 08-05-2003, 06:15 PM   #4
RETIRED
BUT, take into consideration, that the front and rear kit from fastbrakes will run me well over 2000 fom what i can see of his website.
and will that even clear my 15's?
Old 08-05-2003, 06:25 PM   #5
Qwikcivic is off the scale
I say go with the usdm 94+ gsr setup. Cheap like you said. If the rotors are in bad shape just buy a set of brembo cross drilled and slotted I've seen them go for $240 for all 4. If anyone has seen them cheaper let me know. Your going turbo right? That setup should be able to stop you, hopefully.
Qwikcivic is offline   Reply With Quote
Old 08-05-2003, 06:54 PM   #6
B16
B16's Avatar
B16 has a reputation beyond repute
B16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond repute
Send a message via ICQ to B16 Send a message via AIM to B16 Send a message via MSN to B16  FaceBook
gsr
EDIT:
and i've heard not so good things about the ebc green pads, you should get hawk hp+ for front and stock cheapo for rear.
Old 08-05-2003, 07:07 PM   #7
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
id say rebuild the calliper if its that cheap and easy
if not there is a set of del sol Si rear brakes sitting in bills garage talk to him
Old 08-05-2003, 07:31 PM   #8
RETIRED
oh yea.. i forgot about those... hrm.....
Old 08-05-2003, 10:48 PM   #9
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
$1042 shipped for me man, but you'll still need the rear caliper replaced. It will clear your wheels. If not, a 2mm spacer will work. You should have more room behind your spokes than I do.
Old 08-05-2003, 11:18 PM   #10
Ride:  93 del Sol Gas sipper
asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
not sure the price of the rears but I found the fronts for 750 at here
HybridGarage
the fronts
For the rears, see if you can convert to the civic SI's or some other 5th gen hb
Old 08-06-2003, 10:31 AM   #11
liquid00meth is off the scale
Send a message via AIM to liquid00meth
I would say fastbrakes, but only cause my advice would be not to skimp out on brakes. Honestly, with that much HP having a very strong and reliable braking system is a definite must. It's not just like a performance issue, its a pretty big saftey thing.
liquid00meth is offline   Reply With Quote
Old 08-06-2003, 11:59 AM   #12
lsvtec's Avatar
Yes, all of Brian's 11" kits will fit under 15" wheels. (I am running the same brake kit as Mike under the same wheels, '94 GSR) If you take his 11.75" kit with the 2 piece rotors you have to run 16" wheels.
Old 08-06-2003, 01:08 PM   #13
E_SolSi's Avatar
this is for the REAR caliper
swapping out the fronts to an 11" setup does absolutely nothing to fix the problem
just swapping the rears to whatever fastbrakes or wilwood offer will fuck his braking up (rear tires will lock before the fronts *not good*)
doing both aparently costs more than he cares to spend right now
i still say check out the price for rebuilding it .... if thats a no go then talk to bill
Old 08-06-2003, 02:26 PM   #14
lsvtec's Avatar
That price ($1042) is for front and rear.
Old 08-09-2003, 03:30 AM   #15
SolLess16 is off the scale
Send a message via AIM to SolLess16
thats funny , in the past week my right rear calliper froze too- where would i go to look for it to be rebuilt -
SolLess16 is offline   Reply With Quote
Old 08-11-2003, 10:20 PM   #16
zombie is off the scale
Is your rear caliper frozen badly, or is your lines all straight. Sometimes a kinked line will keep a brake down, happened to me when me an my friends where changin brakes on a 1999 accord. Damn that was some bad shit, kept that brake down the whole time. So make sure there is no kink anywhere. I'm sure you've already done this but i'm just trying to help out.
zombie is offline   Reply With Quote
Old 08-13-2003, 08:17 AM   #17
CRX-YEM's Avatar
Ride:  91 CRX
CRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud of
Send a message via ICQ to CRX-YEM Send a message via AIM to CRX-YEM Send a message via Yahoo to CRX-YEM myspace  FaceBook
rebuild the caliper
or option number 4. you could always sell the brembo that you have for the rear.
and buy the correct brembro for the delsol vtec.
CRX-YEM is offline   Reply With Quote
Old 08-24-2003, 03:56 AM   #18
Xentric is off the scale
Rebuild the calipurs just to get you by. If you wait you can probably get a great deal on the 5 Lug from some stupid fuck that overspent and needs to get a quick buck to pay the rent.
Xentric is offline   Reply With Quote
Old 08-26-2003, 04:24 AM   #19
RETIRED
well, i ended up buying a re-manu caliper from majestic for $100 bucks.
fuck it. it will do for now.
thanks for all the replies
Please Vote for My Friend!!!!! adnoh Members' Lounge 13 06-17-2004 07:04 PM
looks like Kerry is gonan get my vote.... pissedoffsol Members' Lounge 7 02-07-2004 01:25 AM
Vote: Best Thread of 2003. pissedoffsol Members' Lounge 45 12-25-2003 04:35 AM
Vote for Angelita (Rockets Dancer pic) cyphen Members' Lounge 15 07-29-2003 07:41 PM
Vote Vote Vote DiGiTal66 HYBRID -> BA-BB /CA-CD 5 05-17-2003 09:17 AM
