I hate brakes, I love brakes
Old 11-29-2003, 02:38 PM   #1
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 165 92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of92b16vx has much to be proud of
Ok, so today me and my buddy David decided to have a go at the conversion that has been sitting down stairs for a while, here's the story.
We started at 10:30, got the car on the lift and assessed the situation. Situation good, all parts need were there and everything was going to be plug and play.
First hurdle you come to is the Torx nuts that keep the spindle from spinning around and around, there are four, and they are bastards. They strip very easily, and are located inside the trailing arms. So we attacked...
Torx key...
and where they are located...
Now, a bit of knowledge to pass on. When you are doing a rear disc conversion, you do NOT have to have the full trailing arm, but if you do you get to avoid the hell of these bolts, so it's your choice, but if you do swap trailing arms you have to man up for a realignment...on to the story...
So we stripped three of these bastards, and had to remove them via force, my favorite part...
David readies the torch...
So, with the stripped bolts you can approach them a couple ways, one is to...
Drill....
But we wound up with the tried and true....burn the fuckers alive method...
Once you have heated them up enough, use a chisel and hammer to pound them in a downward motion till they break and eventually unscrew, or, chisel a slot into them, let them cool and use a large flathead and unscrew them, we used both depending on which one it was and where it was located if we had enough access to it.
Ahhhh....sweet victory...
Now just reverse the process of removal, minus the torch and drill...
Damn, that's a lot of work you say for just the same rear disc, well no they are about an inch bigger...
And are matched to the front, which are going on sometime this week.
So once you are done, not that we are, but you know what I mean, you're going to need some wheels that are going to fit the new lug pattern. This is where everyone gets to laugh, I had to use some Saab rims, as they were the only ones in the junkyard that had tires, and would fit the lugs and hub bolt ring, so laugh it up...
Planning, planning, planning, I can not emphasize this enough. I am lucky and have a full shop with lifts and tools at my disposal, but you need all the little things that are going to possibly give you troubles, like having extra torx bolts, correct brake cables, and lines, pads, rotors, etc..
Well I hope you enjoyed my day, and maybe someone can find some use in the half hour I spent writing it up, cheers bitches.
95 CX|B16A2
Old 11-29-2003, 03:43 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 291 E_SolSi has a reputation beyond repute
cool shit.... what brakes did you end up using????
looks like you had some fun
Originally Posted by Celerity View Post
E has a way with words, a way that should be reserved for beer ads and television show / movie premiers.
"Stop horsing around with that complete childish batshit that you call <insert competitor product name>. Grow up and be a fuckin man and buy <insert product name>. If you don't, you might as well squat to pee, candy ass"
"My name is E, and I approve this message"
МОΛΏΝ ΛΑΒΈ
Old 11-29-2003, 03:45 PM   #3
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
They are from the europeon civic five door, basically a sedan with hatchback instead of a trunk,same as the aerodeck, but it's a wagon. Both have a trim with the B18C4, so they get some nice big brakes
95 CX|B16A2
Old 11-29-2003, 03:54 PM   #4
E_SolSi's Avatar
sweet
grab the engine while your at it
МОΛΏΝ ΛΑΒΈ
Old 11-29-2003, 05:50 PM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
FYI- you don't need the trailign arms cuz you already HAD discs. those with drums have different' trailing arms
Old 11-29-2003, 05:57 PM   #6
Banned
Rep Power: 0 sportlinecrx is off the scale
those saab rims look just like a set of wheelcovers i used to have. nice work though. swapping brakes > me
sportlinecrx is offline   Reply With Quote
Old 11-29-2003, 06:17 PM   #7
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by pissedoffsol+Nov 29 2003, 11:50 PM--><div class='quotetop'>QUOTE(pissedoffsol @ Nov 29 2003, 11:50 PM)</div><div class='quotemain'> FYI- you don't need the trailign arms cuz you already HAD discs. those with drums have different' trailing arms [/b]
Nope, they're the same, it's just easier to swap the whole thing.
<!--QuoteBegin-E_SolSi Posted on Nov 29 2003
@ 09:54 PM
sweet
[/quote]
I wish, these were given to me by a friend that was cleaning out his garage for storage space, unfortunately the motor, and all the other good stuff I could use was given to Honda (he used to work there) for a customers car.
95 CX|B16A2
Old 11-29-2003, 07:54 PM   #8
Rep Power: 18 Canuck 93 Civic Si is off the scale
Send a message via ICQ to Canuck 93 Civic Si
Originally posted by 92b16vx+Nov 29 2003, 06:17 PM--><div class='quotetop'>QUOTE(92b16vx @ Nov 29 2003, 06:17 PM)</div><div class='quotemain'> <!--QuoteBegin-pissedoffsol@Nov 29 2003, 11:50 PM
FYI- you don't need the trailign arms cuz you already HAD discs.* those with drums have different' trailing arms
[/b][/quote]
Yup, i had to go through the same thing on the right side on my car. The trailing arm i swapped in was bent. No one i contacted knew if the trailing arms were the same, so i had to find out for myself. I posted that up somewhere .
btw: if you heat up the torx bolts BEFORE you hit them with the impact gun, they come out just fine, without breaking
Are you sure it was something you read in a book. Are you sure it wasnt..... Nothing?
Canuck 93 Civic Si is offline   Reply With Quote
Old 12-01-2003, 03:32 PM   #9
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 265 Calesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to behold
Nope, they're the same, it's just easier to swap the whole thing. [/b][/quote]
Yup, same thing- most people just replace the whole arm and not the hub assembly.
Old 12-01-2003, 04:18 PM   #10
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by Calesta+Dec 1 2003, 09:32 PM--><div class='quotetop'>QUOTE(Calesta @ Dec 1 2003, 09:32 PM)</div><div class='quotemain'>
Yup, same thing- most people just replace the whole arm and not the hub assembly. [/b][/quote]
Ya, I wish I had the other trailing arm, but it was destroyed in the wreck After all was said and done, I would have MUCH rather done another alignment than the hell of try to remove the stripped torx nuts.
95 CX|B16A2
Forum Jump
Post Your Current Playlist Prowler Members' Lounge 9 06-27-2004 09:33 PM
Me vs Ex g/f IDMaxGuy Members' Lounge 30 04-13-2004 01:55 PM
License Plate Pic. Loco Honkey Members' Lounge 17 06-20-2003 01:20 AM
Your Favorite Song brian11to1 Members' Lounge 22 05-22-2003 10:11 AM
Civic Sir Brakes IceBolt Wheels / Suspension / Tires / Brakes 1 04-19-2003 06:50 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
