Ingalls Style Front UCA Camber Kit vs. Fender Clearence
Old 11-27-2005, 07:54 AM   #1
Runs like a scalded dog!!
FamilyD's Avatar
Ride:  Two '92 Si's and an '89 CRX
Rep Power: 12 FamilyD is an unknown quantity at this point
Does anyone have any experience with inner fender clearence issues @ the front UCA... and possible remedies???
Have totally disassembled front & rear suspension... replaced all old stock bushings with Energy Suspension replacement bushings... new shocks w/2.5" lowering springs (not coilovers) at the ready... have just begun reassembly... far from finished... still on jack stands.
It appears as though anything more than just slight outboard adjustment of the Ingalls style adjustable front UCA bushings will cause contact between the "tip" of the UCA outboard of the ball joint & the spot welded "lip" formed between the shock tower/UCA housing & the steel portion of the inner fender.
I can't say for certain how much of this adjustment will be necessary untill I get back on the ground and on an alignment rack... just trying to stay ahead of the curve.
FamilyD is offline   Reply With Quote
Old 11-27-2005, 10:13 AM   #2
Rep Power: 33 driver1 is an unknown quantity at this point
if the style camber kit u have is the one that replaces the peices where the uca mounts, with some adj. units then there is nothing that i know of that u can do about it. I had the same issue in my car with that style camber kit, and ended up having to swap over to an adj. balljoint setup to fix the issue. Some cars accept them others dont. My brother put this style on his 92 integra and it worked just fine no clearance issues at all no noises. I would suggest testing the clearance and if u see its gonna hit dont just put it together and try to get by with it, cause it will make loud and disturbing noises when u hit bumps goin down the road.
94 Honda Accord, jdm h22 swapped daily driver
04 cbr600rr fun toy
95 toyota tacoma, lifted winter truck
driver1 is offline   Reply With Quote
Old 11-28-2005, 11:55 PM   #3
FamilyD's Avatar
<div class='quotetop'>QUOTE(driver1 @ Nov 27 2005, 09:13 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Thanks for the reply...
Yes... that is the style... with the adj. UCA bushings. What make & model did you experience the problem with??? And the adj. ball joint... was that the upper or lower???
