launching with drag radials
Old 06-21-2009, 06:10 PM   #1
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
Default launching with drag radials
i picked up a set of wheels with some nearly new bfg drag radials on them 205/50/15. i have never used any type of slicks or drag tires before so i wanted to get some advice before i take it to the track.
what air pressure should i air them down to at the track?
proper technique to heat them up? how much spinning?
what kind of 60ft time can i expect? i run 2.3s on street tires.
mdpsEG is offline   Reply With Quote
Old 06-22-2009, 11:40 AM   #2
mdpsEG's Avatar
no one on here has any experience with drag radials? cmon guys...
also i have adjustable shocks all around... should i go full stiffness on all 4 for the track?
Old 06-22-2009, 02:11 PM   #3
CAFROG's Avatar
Ride:  '92 Hatch si w/B16 (wannabe EG6)
Rep Power: 26 CAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to behold
I would try mid-low 20 lbs in the tires (just my opinion)
Dont be silly and think you need all that water on your tires (use just a little if any)
Stiffness can help but too much and your hopping all over the place.
Just go hang out and give it a try. Launch around 4.5-5K and just be observant
of what the car does and make adjustments.
You should be a little under 2 seconds for 60ft time
CAFROG is offline   Reply With Quote
Old 06-23-2009, 01:20 PM   #4
mdpsEG's Avatar
i guess ill start with all 4 shocks on full stiffness and if i get wheel hop ill loosen the front up. ill start at 25 psi and see how that does unless someone else has some firsthand experience with bfg's that says otherwise. should be hitting the track this friday if the weather is ok.
any other advice anyone?
Old 06-23-2009, 04:24 PM   #5
CAFROG's Avatar
Good luck with it all. Hope your axles are up for the challenge too. (they should be fine if they're in good condition) I would load the clutch a little too (hold the e-brake up a little while engaging the clutch ever so slightly) I truly believe that helps avoid a shock to the system when power is transferred to the axles.
Bring an air pump if car bogs down with 25psi in tires....or just launch higher
good drag radials? micah Wheels / Suspension / Tires / Brakes 10 05-08-2005 03:10 AM
Fat fives and drag radials...w00t! civicious Auto Multi-Media 4 01-25-2005 06:31 PM
WTB BF drag radials tphan4 Parts: For Sale/Trade/Wanted 0 09-07-2004 08:58 PM
HID kit, 95 GSR wheels, drag radials, JVC headunit nfn15037 Parts: For Sale/Trade/Wanted 7 05-07-2004 05:54 PM
BFG G Force Drag Radials *NEW* FerioVtec94 Parts: For Sale/Trade/Wanted 0 11-17-2003 10:01 AM
