Hello evryone,
I am again in need of some help. I did a lowering spring swap on my 91 civic but now the car is out of alignment. what I would like to know is what kind of adjustments do I need to make in order to get my alignment back into place. Do I need to buy a caster and camber kit for the front end? I also read a posting about putting some washers on the upper control arm (back of the car) to get the right aligngment but what can I do to the front of the car to get right aligngment? I am thinking about doing a reardisk brake convertion on the car so I am going to wait until I finish the brake convertion before I take the car to get align. For the rear brake convertion I got all the parts from an integra 90-93 but it had the abs system on it. Can I still use this set up on my 91 civic if I remove the abs system from it?thxz guys. P.S here is a pic of the rear disk brake system. Last edited by twinvtec; 08-01-2007 at 02:39 PM. Reason: . |
you can use the integra rear disk brakes but you need to use the si e-brake cables... you cant use the the abs proportion valve so your going to have to get a si proportion valve if your not changing the front disk brakes but if you are changing the fronts you can use a integra (non abs) proportioning valve...hope this helps
| How To -auto To Manual | hondaburner95 | Accord | 34 | 09-14-2008 07:15 PM |
| ****GARAGE SALE..SOHC DREAM...COME ONE COME ALL**** | whos_the_master | Parts: For Sale/Trade/Wanted | 24 | 02-17-2006 10:21 PM |
| zc swap into 85 crx? | devnjeff | HYBRID -> ED-EF / DA | 4 | 07-10-2005 11:09 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| Part Numbers for 89Si/B16 OBD0 Swap | steelbuster | Swap Articles | 0 | 11-16-2003 07:36 PM |
