New calipers and discs
Old 08-21-2003, 02:39 AM   #1
ando is off the scale
Thumbs up
I have a 96 Civic Coupe. After I swap my D16Y to a B16A I would like to upgrade my brakes. Could you please suggest a good set up for the front discs and calipers? Keeping in mind that my rear brakes are drum brakes which im going to leave as they are.
Thanks.
ando is offline   Reply With Quote
Old 08-21-2003, 02:16 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
lsvtec is on a distinguished road
www.fastbrakes.com
They have an 11" disc with 4 pistons wilwood calipers for that car.
It makes no sense at all to upgrade the front brakes when you have not intention of upgrading the rears.
lsvtec is offline   Reply With Quote
Old 08-21-2003, 04:55 PM   #3
sohcslammer's Avatar
sohcslammer is an unknown quantity at this point
That's not true. A front brake upgrade is better than nothing. And I would go all wilwood.
sohcslammer is offline   Reply With Quote
Old 08-21-2003, 05:15 PM   #4
endlesszeal has a reputation beyond repute
endlesszeal has a reputation beyond reputeendlesszeal has a reputation beyond reputeendlesszeal has a reputation beyond reputeendlesszeal has a reputation beyond reputeendlesszeal has a reputation beyond reputeendlesszeal has a reputation beyond repute
depends on budget.. if its a tight one, id got with fastbrakes too.. if not, i stay either stop-tech or brembo.. more than half, i believe, of the ultimate street car challenage, used stop-tech and results werent disappointing.. however, a stock gt-r with stock brembos did just as well if not better than those with stop tech..
endlesszeal is offline   Reply With Quote
Old 08-21-2003, 06:31 PM   #5
B16
B16's Avatar
B16 has a reputation beyond repute
B16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond repute
Send a message via ICQ to B16 Send a message via AIM to B16 Send a message via MSN to B16  FaceBook
i'd probably just go GSR front brakes and some hawk pads and call it a day.
Old 08-22-2003, 12:07 PM   #6
lsvtec's Avatar
If you aren't touching the rear brakes then you don't want to go crazy up front.
Actually it is true. If you choose to only upgrade the front brakes al you are doing is making the front setup do more of the braking. If instead you choose to upgrade the stopping power on both front and rear you have increased the stopping power of the car, this also allows you some control over the front to rear ratio.
Old 08-22-2003, 12:13 PM   #7
hcivic.com is on a distinguished road
hawk pads brembo blanks
hcivic.com is offline   Reply With Quote
Old 08-27-2003, 12:06 AM   #8
dragoon118 is off the scale
go with the gsr front brakes, brembo blanks, and some good pads and spend the rest of the money you will save on some go fast parts.
dragoon118 is offline   Reply With Quote
Which calipers and rotors legutki Wheels / Suspension / Tires / Brakes 2 01-20-2004 03:29 AM
Type R Brake Calipers For Sale Racecraft Parts: For Sale/Trade/Wanted 0 05-12-2003 07:28 AM
