Noise from the front wheel question...
Old 10-12-2009, 03:25 PM   #1
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Default Noise from the front wheel question...
I was wondering if anyone can help me determine what might be the cause of a noise coming from what I believe is my left front wheel. The best way to describe the noise is when I hit the brakes it sounds like the caliper or pad is hitting the disc. It is sort of a grabbing or popping sound. It kinda sounds like the pad is too short and when the brakes grab the pad hits the little shelf that holds the clip. I know that is not what is happening I just think it is a good way to describe the noise. It mainly makes the sound when I brake, but sometimes it makes it when I accelerate as well. I checked all the bolts around the area to see if anything was loose (susp. and brakes) and everything seems good.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 10-12-2009, 05:01 PM   #2
SlushboxTeggy's Avatar
Ride:  1997 Integra
Rep Power: 196 SlushboxTeggy has a reputation beyond repute
SlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond repute
Send a message via AIM to SlushboxTeggy Send a message via MSN to SlushboxTeggy
How old are the pads and rotors?
I would also check the pad for any uneven wear. May help you figure out what's wrong.
Like water on a duck's back, just let it roll off...
RIP Shaunie T. O'Reilly- 1986-2006
SlushboxTeggy is offline   Reply With Quote
Old 10-12-2009, 05:31 PM   #3
Conan The Hondarian
wikedeye's Avatar
I dont know how old the rotors are...they came with the car when I bought it 4 years ago. The pads are less then a year. I will check it out tomorrow. I have noticed that the rotors have grooves in other words they are not smooth, I dont know if they are supposed to wear smoothly or not.
XBL: Wikedeye
Old 10-12-2009, 11:51 PM   #4
Ride:  1997 Integra
Replace the rotors and pads. Rotors are most definitely bad. Pads are probably bad because they have been wearing on bad rotors for a year. Replace the rear sets while you're at it. I doubt they are all that good.
Old 10-13-2009, 05:55 AM   #5
Conan The Hondarian
wikedeye's Avatar
Ok thanx...I was planning on doing it soon anyway, so now I have a good reason to.
XBL: Wikedeye
Old 10-15-2009, 09:23 PM   #6
Conan The Hondarian
wikedeye's Avatar
I replaced the rotors and pads and the noise is still there. Any other ideas?
XBL: Wikedeye
Old 10-15-2009, 09:42 PM   #7
91_stylin_civic's Avatar
Ride:  91 civic hatch w/b16 and 91 civic hatch project car
Rep Power: 8 91_stylin_civic has a spectacular aura about91_stylin_civic has a spectacular aura about
Did you check the balljoints or tie rod ends for play? Also check the bushing?
91_stylin_civic is offline   Reply With Quote
Old 10-16-2009, 06:02 AM   #8
Conan The Hondarian
wikedeye's Avatar
All the bolts and nuts are on tight. The only thing I noticed was when you pull on the pass. side ties rod there is a tiny bit of movement. It was more noticeable when I had the suspension loaded so I could change the end link bushings. I jacked up the suspension, change the bushungs, then pulled on the tie rod.
XBL: Wikedeye
Old 10-22-2009, 05:26 PM   #9
Conan The Hondarian
wikedeye's Avatar
I still cant figure out what the problem is. Today I pulled on the wheel (towards me at the top) and noticed that the wheel moves outward. Would the ball the joints on the upper control arm allow the wheel to do that? The drivers side has more play in it then the pass. I checked the crown bolts when I changed the rotors and they are tight.
XBL: Wikedeye
Old 10-25-2009, 11:03 AM   #10
when you move the wheel out is the upper ball joint moving? If so you need new upper arms
Old 10-25-2009, 11:11 AM   #11
Conan The Hondarian
wikedeye's Avatar
yeah the wheel actually pulls towards me a little bit (maybe an 1/8th of an inch on the driver side, less on the pass side).
XBL: Wikedeye
Old 10-25-2009, 11:40 AM   #12
I think its time for some new upper arms. I dont think you can just replace the upper ball joints, i know on my 91 i had to replace the arms.
Old 10-25-2009, 11:43 AM   #13
Conan The Hondarian
wikedeye's Avatar
I have skunk2 arms and they sell replacement ball joints, so when I get some money next week I will replace those. Hopefully that will fix my problem.
XBL: Wikedeye
Old 10-25-2009, 11:53 AM   #14
good luck let us know
Old 10-25-2009, 01:35 PM   #15
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Could also be bad wheel bearings. Jack the car up and wiggle the tire back and forth, like you are turning it. If it has play there too, there is a good chance the bearings are shot.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 10-25-2009, 01:44 PM   #16
Conan The Hondarian
wikedeye's Avatar
should it be in gear?
XBL: Wikedeye
Old 10-25-2009, 01:50 PM   #17
Ride:  99 ex, d16y8 PnP, headers, exhaust, crower cam, 135whp
Rep Power: 4 josh_crewdson@y is on a distinguished road
If it's a wheel bearing it would make a humming/whining noise above 10-25mph.. (from past experience) i'd say it's your ball joints.
josh_crewdson@y is offline   Reply With Quote
Old 10-25-2009, 01:58 PM   #18
Conan The Hondarian
wikedeye's Avatar
There is definitely no whinning or humming. The only time you hear any noise is when braking, sometimes at the beginning of acceleration, and during turns when bumpy.
XBL: Wikedeye
Old 10-25-2009, 02:32 PM   #19
Yeah sounds like ball-joints, especially if it makes noise when braking, and going over bumps..
Old 10-25-2009, 04:27 PM   #20
Rep Power: 6 bluejcivic is on a distinguished road
probably the bushings in your upper comtrol arms, maybe the balljoint too, but i would take a close look at your wheel bearing and see if there is play
bluejcivic is offline   Reply With Quote
Old 10-26-2009, 12:43 AM   #21
Senior Citizen
91civisedaner's Avatar
Ride:  1991 civic sedan 1972 datsun 620
Rep Power: 3 91civisedaner is on a distinguished road
Check yer wheel bearings for sure,my driver side is gone and it dosen't make noise till i'm on the free way
91civisedaner is offline   Reply With Quote
Old 10-26-2009, 05:59 AM   #22
Conan The Hondarian
wikedeye's Avatar
There is no noise while driving only when braking and sometimes when I begin to accelerate, but I will check them.
XBL: Wikedeye
Old 10-26-2009, 05:44 PM   #23
Ride:  1997 Integra
One of my favorite methods of diagnosing... Bring it to a mechanic for an oil change and mention something is wrong with the suspension. They will figure it out and call to ask if they should replace it. Say no. Pick it up and do it yourself. Well worth the couple of extra dollars you pay for the oil change.
Old 10-26-2009, 05:48 PM   #24
Conan The Hondarian
wikedeye's Avatar
sounds like a good idea.
XBL: Wikedeye
Old 10-26-2009, 05:56 PM   #25
Jizared97's Avatar
Ride:  97 ex coupe, 89 240sx
Rep Power: 44 Jizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant future
Send a message via AIM to Jizared97 myspace
Jack the car up and rock the tire back and forth, grabbing it at the top and bottom not the sides. If it has excessive play its a wheel bearing. Rocking it as if you are turning isn't going to necessarily point you towards a bad wheel bearing, its more than likely going to determine tie rods being wore or your rack is bad. But since you said you have a skunk2 camber kit, take the A arm off and check the bushings. They are probably wore. I've learned that from experience. I have the same problem now. I also replaced the ball joint and it still did the samething. I'd check the bushings before possibly wasting $43 on a balljoint.
Jizared97 is offline   Reply With Quote
loud wheel noise custompainter Civic and del Sol - EG and EK 9 12-16-2007 10:04 AM
Wheel Clicking Noise randerson165 Wheels / Suspension / Tires / Brakes 12 02-23-2004 12:24 AM
Weird Noise Coming From Front Axle La_Pieuvre General Tech and Maintenance 7 02-02-2003 04:51 PM
Whining Noise From The Front End lsvtec General Tech and Maintenance 12 01-19-2003 07:56 PM
clicking noise in right front axle kyleirwin General Tech and Maintenance 4 10-27-2002 02:07 AM
