#2 | |
Member of the 20 nut club
master of slave cyl
МОΛΏΝ ΛΑΒΈ |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
Hmm, same problem I have.....Maybe I should replace that...
When this is all over I think we should get an apartment together. |
#4 | |
#5 | |
Blah blah blah....
Check the little bleeder nipples to make sure they are not leaking. When I had my calipers worked on, I had to replace the washers on the banjo bolts as well. If you pulled those off at all, check those too. Did you fully empty the master cylinder? Because if you did, it will also need to be bled.
#8 |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
are you running with brand new brake fluid?
cause old fluid could be your problem also, does it get spongy ALL the time, or only during hard braking? what kind of car with what brake setup? __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
#12 | |
#14 | |
#16 |
B happy
Ride: dohc 95 egg
You more than likely still have air in the system, possibly from the master cylinder getting some in it during bleeding, or air going back into the lines during bleeding. Usually when equipment fails, it's isn't intermitent, it's consistant.
Bench bleed the MC and rebleed the system. If that doesn't fix it, it's possible the piston seals are bad also, that's is, if you can find something somewhere else. __________________
#18 |
B happy
Ride: dohc 95 egg
Bench bleeding is done to get air bubbles out of the MC that are there because air got in A. during bleeding, or B on a brand new one that hasn't had fluid in it before.
http://www.honda-tech.com/zerothread?id=874191 Air in the MC is a common problem because it is often done wrong, and the symptoms will remain. __________________
#20 | |
Edit: forgot, no the MC will not fit without replaceing the booster, but a 15/16th from a 91 EX will |
