Positive and Negative Effects
Old 05-23-2009, 04:41 PM   #1
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Default Positive and Negative Effects
I see a lot of threads of people asking things like, "How low should I go?" "Are wider tires always better?" "What wheel offset should I run?" "How much camber is too much?" ECT...
Well, I came across this quick little guide, in my book for my suspension class, that I think people could reference just for a ball park idea for what you want/need.
Let me start by saying it's not a perfect world. There are pros and cons to everything so you just have to take the good with the bad...
Change - Positive Effect - Negative Effect
Increase Tire Width - Increased Dry Traction - Hydroplaning in wet conditions, Requires wider wheels(in some cases), Reduced fender well clearance
Increase Wheel Offset - Increased track width, Reduced weight transfer - Aerodynamic drag, Increased wheel bearing load, Reduced tire clearance
Lower Center of Gravity - Reduced weight transfer, Reduced body roll - Reduced ground clearance, Reduced wheel travel
Increased Spring Rate - Reduced body roll - Increased bump shock, Harsher ride
Increase Negative Camber - Increased tire cornering power - Tire wear, Steering/Braking pull, Reduced straight line traction
Increase Positive Caster - Straight line stability, Improved camber on turns - Harder Steering, Possible shimmy(wheel shake)
Lower Roll Center - Less camber change on roll - Increased tire scrub(tire changing path/direction) on roll
Replace Suspension Bushings w/More Solid I.E. Polyurethane - Reduced alignment deflection(roll steer), Faster anti-roll bar response - Increased vibration, Harsher ride, Replacement bushings usually require lubrication
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 05-23-2009, 06:26 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
good info.. stickied
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 05-23-2009, 08:36 PM   #3
I'll be back...
Thanks Clint
Old 05-24-2009, 02:05 AM   #4
Neon Owner
cjvictoria's Avatar
Ride:  '04 NEON
Rep Power: 89 cjvictoria has a reputation beyond repute
cjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond repute
Send a message via Yahoo to cjvictoria
me likes this new knowledge that hath been bestowed upon me
XBOX LIVE - jdmJO3
>>>Click ME<<<
I have D16Y7 injectors and fuel rail fo sale. pm me if interested.
cjvictoria is offline   Reply With Quote
Tags
alignment, camber, lowering, offset, rate, rims, springs, tires, wheels
versitility- negative camber or not? jon_the_accord_man Wheels / Suspension / Tires / Brakes 13 10-18-2008 07:02 PM
NEGATIVE - Blaastperformance bjfisher Members' Lounge 10 04-13-2007 07:31 PM
Negative wire off of coil?? SolLess16 General Tech and Maintenance 1 03-31-2005 10:24 PM
ground effects kit 4DRonDUBS Body / Exterior / Interior / Cosmetics 2 10-05-2004 07:25 PM
Need Some Help On Ground Effects quick_civic Members' Lounge 7 04-17-2003 03:15 AM
