power steering removel
Old 12-07-2003, 10:26 PM   #1
streetracinghn is off the scale
Send a message via AIM to streetracinghn Send a message via Yahoo to streetracinghn
Thumbs up
i have searched and came up empty. i need to know how to take the power steering out of a 91 accord lx and make it manual. im looking for a how to. step by step. ive read all the post but they dont help
streetracinghn is offline   Reply With Quote
Old 12-07-2003, 10:29 PM   #2
Ride:  93 del Sol Gas sipper
asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
check out team-toilet racing or C-speedracing.
http://www.teamtoilet.com/
or
c-speedracing.com
I think one of them have a how to.
Old 12-07-2003, 10:48 PM   #3
i tried them but they dont have one. can ne one help
Old 12-07-2003, 11:21 PM   #4
Ride:  '94 DX hatch
ahedau is off the scale
Send a message via Yahoo to ahedau
This is gonna sound stupid but.... why don't you just take the belt off the power steering pump & plug the lines?
I was told that the gearing in the p/s rack is a faster ratio than in the manual rack. However, like most things someone else said that's backwards.
All I do know is the guys with power assisted steering can work the slolom & tight turns faster than I can w/ manual.
If that won't work try this:
removal
1. raise the front of the vehicle & suport it w/ jackstands. Apply the parking brake.
2. Place a drain pan undr the steering gear (power steering only). Remove the hoses/lines and cap ends to prevent excessive fluid lose & contamination.
3. Mark the relationship of the intermediate shaft universal joint to the steering gear input shafrt & remove the pinch bolt
4. Separate the tie-rod ends from the steering knuckle arms
5. Support the steering gear & remove the mounting bolts. Lower the unit, separate the intermediate shaft from the steering gear input shaft & remove the steering gear from the vehicle.
INSTALLATION
1. Raise the steering gear into position & connect the intermediat shaft, aligning the marks.
2. Install the mounting bolts & washers and tighten them securely (28 ft/#)
3. Connect the tie-rod ends to the steering knuckle arms (32 ft/#)
4. Install the lower intermediate shaft pinch bolt & tighten it securely (??)
5. Connect the power steering hoses/lines to the steering pump resovior w/ reccomended fluid
6. Lower the vehicle & bleed the steering system
Now, if you buy a Haynes manual like I did, you get pretty pictures that might life easier!!
ahedau is offline   Reply With Quote
Old 12-08-2003, 06:05 AM   #5
deth101 is off the scale
Send a message via MSN to deth101 Send a message via Yahoo to deth101
before your gen but it couldnt be that different, I'm pretty sure I saw a walkthrough on 3geez.com
deth101 is offline   Reply With Quote
Old 12-08-2003, 07:48 AM   #6
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
Originally posted by ahedau@Dec 8 2003, 12:21 AM
buy a Haynes manual
buy a HELMS manual.
http://www.helminc.com
Old 12-08-2003, 02:01 PM   #7
FüK-VTEC
civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious
civicious is offline   Reply With Quote
Old 12-08-2003, 03:37 PM   #8
i looked on 3geez .com but couldnt find it. thats what im talkn about taking the belt and pully off im lookn for a how to or a step by step to do this
Old 12-08-2003, 04:00 PM   #9
B16
B16's Avatar
B16 has a reputation beyond repute
B16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond repute
Send a message via ICQ to B16 Send a message via AIM to B16 Send a message via MSN to B16  FaceBook
http://honda-tech.com/zerothread?id=184202
http://honda-tech.com/zerothread?id=462824
http://honda-tech.com/zerothread?id=563114
these should answer all your questions
Power Steering issue AmonDin HYBRID -> BA-BB /CA-CD 5 05-01-2004 07:15 PM
Power Steering Removal Kit? turbo99 General Tech and Maintenance 14 02-25-2004 01:25 AM
a/c and power steering civicious General Tech and Maintenance 6 07-08-2003 01:30 AM
Power Steering Tight Jazzy19 General Tech and Maintenance 5 03-24-2003 01:56 AM
Civic Cx Power Steering Question vietec HYBRID -> EG-EK / DC 5 01-16-2003 07:42 AM
