Quick Question On E-Brake
Old 05-23-2008, 03:06 PM   #1
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
YBLEGAL has a brilliant future
myspace
Question Quick Question On E-Brake
I'm doing a rear disc conversion to my 2000 Civic EX. I've used '90 Integra rear calipers and spindles on my Civic's trailing arms along with 2000 Civic Si parking brake cables.
I have not gotten my hydraulic brake lines completly installed yet, but when I went to test the parking brake, it would not lock the rear wheels. Should it be able to?
There is no fluid in the calipers or the brake lines, so could that be the reason? This is my first time bleeding brakes and messing with an unbled system. BTW I ran all new brake lines. So there's litterally nothing in the lines. But I assume it's called an emergancy brake for reasons related.... so idk.
Anyone have experiance they can tell me if it should work now or not? I just want to know if there's a problem that needs corrected before I get too much further.
Thanks
Old 05-23-2008, 04:23 PM   #2
|Chaz|'s Avatar
Ride:  92' EG Sedan
|Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
I didn't realize it was possible to use 90' Integra rear calipers and spindles on a 00'. I thought it had to be from a 94'-01' Integra?
|Chaz| is offline   Reply With Quote
Old 05-23-2008, 06:42 PM   #3
YBLEGAL's Avatar
myspace
Ya for sure. I forget but when I was searching for compatibility in the past, I may have found something that said it worked. Or, I just went to the junkyard and eye'd it out . 7CLP13S is the same Nissin part number stamped to the calipers that you would find on even a '99-00 Si rear caliper. as for the spindle, it bolted right up to my trailing arms. And it sits fine. Rolls fine. All indications are they're a direct fit.
I think your thinking of swaping the entire trailing arm. Sort of the lazy way so you don't have to mess with those star bolts in the back of the spindle.
Here's the link to my progress:
5th Upgrade Session - Springs, Mounts, IM Gasket, AC Remove, Wiring, Rear Disc Conversion, Steel Braided Brake Lines
Old 05-23-2008, 11:42 PM   #4
|Chaz|'s Avatar
Ride:  92' EG Sedan
Oh yea I was thinking of trailing arms, thanks for clearing that up.
Old 05-24-2008, 10:06 AM   #5
YBLEGAL's Avatar
myspace
Anyone know of it should lock the wheels now or not??
Old 05-24-2008, 10:09 AM   #6
K2e2vin's Avatar
Ride:  88 Honda Civic HB
K2e2vin has a reputation beyond repute
K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
Yes, it should. Maybe it just needs to be adjusted?
Old 05-24-2008, 10:10 AM   #7
YBLEGAL's Avatar
myspace
damn that's the thing, i can screw the adjustment screw down till i run out of threads, and it still wont lock when i pull it all the way up.
any suggestions? am i supposed to rotate the caliper piston and make it pop out more or something? again, noob here!
Old 05-24-2008, 10:15 AM   #8
K2e2vin's Avatar
What cable are you using?
If you can, have someone check to see that it's even actuating the lever.
Old 05-24-2008, 10:21 AM   #9
YBLEGAL's Avatar
myspace
it moves the lever some.
i'm using 2000 civic si cables.
it does make the brake pads touch a little bit, but wont even lock it strong enough to hold it on a level surface.
Old 05-24-2008, 01:07 PM   #10
Jizared97's Avatar
Ride:  96 Civic CX, 89 240sx
Jizared97 has a brilliant future
Send a message via AIM to Jizared97 myspace
I'm having the same problem. I'm thinking that there is some way to adjust the lever in the back.
I haven't actually made an effort to try yet.
Jizared97 is offline   Reply With Quote
Old 05-24-2008, 03:10 PM   #11
K2e2vin's Avatar
Try using the correct cables.
Old 05-24-2008, 04:06 PM   #12
YBLEGAL's Avatar
myspace
then in your opinion, what are the correct cables? the calipers are the same Nissin part numbers as 2000 civic si calipers. my vehicle is a 2000 civic ex. the si that year was a coupe. as well as my EJ8. everyone says use the 2000 civic si cables, which makes perfect sense to me.
so what's the right cables then?
your absolutly certian that they should hold with a bone dry hydraulic system?
Old 05-24-2008, 09:18 PM   #13
K2e2vin's Avatar
Whoops, I didn't realize you were already using Si cables. Yes, those should be the correct ones. Have you made sure they're routed correctly?
Not sure with a bone-dry hydraulic system, but it should still hold. When I was working on a EG with rear discs, I had forgot to put the parking brake down and the caliper wouldn't move even after the hydraulic lines were taken off.
Old 05-24-2008, 10:11 PM   #14
you get the BRAKE
LS_VTEC's Avatar
Ride:  all motor eg6
LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Send a message via AIM to LS_VTEC
The parking brake system is in no way tied to the hydraulic brake system. The parking brake is cable actuated. Try adjusting the parking brake cable itself.
LS_VTEC is offline   Reply With Quote
Old 05-25-2008, 12:17 AM   #15
YBLEGAL's Avatar
myspace
wow man. you take me for that much of a noob? did you read? lol.
i installed it. i know this. +, duh.
now then can you tell me if the parking brake should lock with enough force to park the car on an incline, with the hydraulic system bone dry?
the easy answer should be YES. but mine does not. so yeah. scroll up and read what i said too, maybe you'll see what i'm doing.
Old 05-25-2008, 01:34 AM   #16
K2e2vin's Avatar
Just a though; bad brake pads or rusted rotors? Have you tried breaking the brakes in? When I had my car sitting for awhile and changed the pads/calipers(rotors were rusty too), it took some effort to stop the car. Once everything was broken in(rust gone and pads bedded in), it stopped just fine.
Old 05-25-2008, 05:42 AM   #17
YBLEGAL's Avatar
myspace
oo yeah forgot to mention, brand new rotors, brand new brake pads, and brand new from acura remanufacured calipers
i cant break the brakes in yet because the motor isnt running yet. maybe.., i did use brake cleaner on the rotors before install tho
Old 05-25-2008, 12:41 PM   #18
Yes, that's road salt.
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
I have the feeling that your calipers aren't setup to the specification gap yet, and that's where your problems are coming from. Try measuring them out, then procede.
I might have missed this, but you should check the actual parking brake lever.
Behind the lever, there's a single cable to twin cable adapter, and if I remember properly, you can adjust that. You may want to just stick with adjusting the lever's single cable, because you don't want bias issues. Try tightening that cable adjuster enough to get the calipers close to spec, I don't remember the tolerances off the top of my head, but get them to spec, then try it your e-brake.
☻/ DIY/Howto HID Projector retrofit
Originally Posted by jeffie7 View Post
Thats it, I'm parting out the Z and getting a fit!
awptickes is offline   Reply With Quote
Old 05-25-2008, 04:05 PM   #19
YBLEGAL's Avatar
myspace
Hmm. Specification gap. I've never heard this term with brakes. I assume the tool to measure would be a feeler gauge.
So I popped open my Haynes and took another read, and see if you can more clearly decipher what they're saying than me please:
General Information
...All brakes are self adjusting. The front and rear disc brakes automatically compensate for pad wear, while the rear drum brakes incorporate an adjustment mechanism which is activated as the brakes are applied, either through the pedal or the parking brake lever.
Seems like maybe I don't need to do any gap setting and they just need fluid in the lines and to be used a few times for them to automaticly adjust? They are rebuilt calipers, so basicly brand new never used thus never auto adjusted to any spec. Again, brand new pads and rotors.
For sure the adjustment nut does not make much of a difference.
Old 05-25-2008, 04:10 PM   #20
awptickes's Avatar
 FaceBook
Oh yeah, I almost forgot about that. They're self adjusting now. Geeze, the technology moves faster than I can keep up. I'm still used to the little alan-wrench tool I have to use to adjust the rears on my fiat.
Just back down a hill a few times with your foot on the brake pedal. When you charge the system that is. If I remember properly, it'll only adjust the pedal, not the e-brake. But I don't have a manual handy, so I'm probably wrong. I think I remember my manual saying something about adjusting the e-brake....
Old 05-25-2008, 04:23 PM   #21
YBLEGAL's Avatar
myspace
hmm i'll take a look at my 96-00 civic factory service manual real quick, i didnt see anything before tho.
i'm trying to see if it should or not now, so i can address the problem soon, if need be. i got a week or more till i can charge the system.
Old 05-25-2008, 04:26 PM   #22
awptickes's Avatar
 FaceBook
I'm a big fan of not dicking around with things until everything is setup.
I'd wait until you charge the system. Although, I don't think it'll make a difference with the problem you've described.
Old 05-25-2008, 04:30 PM   #23
YBLEGAL's Avatar
myspace
Well I'll be damn'd!
Page 19-6
NOTE: After servicing the rear brake pads or calipers, or the rear brake shoe, loosen the parking brake adjusting nut, start the engine, and depress the brake pedal several times to set the self-adjusting brake before adjusting the parking brake.
Thanks to everyone, I am a retard! haha. +rep for all
Old 05-25-2008, 04:32 PM   #24
YBLEGAL's Avatar
myspace
Yeah thanks for the info. I didn't think that would be an issue since it's an emergancy brake. It would be assumed to work without the fluid. But that makes sense. This is the first time I've bled brakes or messed with the brake system. A large undertaking, but when I'm finished, I should have learned much. And I am. So thanks again.
Old 05-25-2008, 04:33 PM   #25
awptickes's Avatar
 FaceBook
Not a problem.
Quick brake upgrade question on my CRX Andrew Wheels / Suspension / Tires / Brakes 1 05-31-2006 03:08 PM
Quick question needs quick response. lol. 5speed4life HYBRID -> ED-EF / DA 5 02-24-2006 02:22 PM
FS: B20a, DMH 3" e-cutout, GSR brake pads, quick release klubhed1 Parts: For Sale/Trade/Wanted 3 12-30-2005 10:24 AM
FS: B20a longblock, DMH 3" e-cutout, GSR brake pads, quick releas klubhed1 Parts: For Sale/Trade/Wanted 1 11-15-2005 07:50 PM
just a quick question 93vicb16a2 General Tech and Maintenance 2 11-10-2005 12:28 PM
